I am looking for a tuning map for a R33 GTR running a Apexi Power FC. Will be using a laptop for the tunning. My GTR has had the following installed:
Garret 2860-7 with HKS Actuators
9:1 CP Pistons
4 inch exaust from the Cat
Its running stock injectors, fuel pump ect.
I am just looking for a map that has the correct details to work from, obviously every car is different and needs fine tuning. I have searched SAU and while there are some great tips (Looking at you Paul), I haven't found any actual map files.
Any help would be appriciated.
https://www.sau.com.au/forums/topic/409107-tuning-map-for-pfc-r33-gtr/
In my opinion, reset and use the base map, then just shave a blanket -5 or so degrees of timing and the car will be fine to drive if you don't give it any stick.
As a safety measure, don't use crap fuel either. The higher the octane rating, the more knock resistant it is.
And the different Compression shouldn't be an issue?
Hence as a safety measure, just do a blanket trim of the ignition, however saying that if you're cruising about off boost then it wouldn't be an issue at all.
