I am looking for a tuning map for a R33 GTR running a Apexi Power FC. Will be using a laptop for the tunning. My GTR has had the following installed:
Garret 2860-7 with HKS Actuators
9:1 CP Pistons
4 inch exaust from the Cat
Its running stock injectors, fuel pump ect.
I am just looking for a map that has the correct details to work from, obviously every car is different and needs fine tuning. I have searched SAU and while there are some great tips (Looking at you Paul), I haven't found any actual map files.
Any help would be appriciated.
https://www.sau.com.au/forums/topic/409107-tuning-map-for-pfc-r33-gtr/
In my opinion, reset and use the base map, then just shave a blanket -5 or so degrees of timing and the car will be fine to drive if you don't give it any stick.
As a safety measure, don't use crap fuel either. The higher the octane rating, the more knock resistant it is.
And the different Compression shouldn't be an issue?
Hence as a safety measure, just do a blanket trim of the ignition, however saying that if you're cruising about off boost then it wouldn't be an issue at all.
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
