Nissan Skyline R33 GTS-T Series 2
Year: 1996
Engine: RB25DET
Transmission: Manual
Kilometres: 160,000
Engine/Driveline:
Hybrid intercooler kit
Custom piping
Hypergear TR43i turbo kit (rated 550hp)
Modified manifold
50mm external wastegate
Car is running 10 pounds
Custom v-band 3inch dump pipe and front pipe all in 1 piece
Jasma 3.5inch catback exhaust that gives it a great rb note
Custom steal 3inch intake pipe
Cold air intake
Tomei Adjustable Cam Gears
Splitfire coilpacks NGK-R spark plugs
Gates Racing timing belt
Bosch 040 fuel pump
Strong and good condition rb25 gearbox
Exedy Heavy Duty Button Clutch
JJR custom tailshaft
Standard LSD Diff.
Interior:
Interior is clean and looked after
Bride Gias bucket seat
Standard Steering wheel
Pioneer double din headunit
4 6inch sony splits
Greddy electronic boost gauge
Greddy turbo timer
Mini ecu that has different settings
Alarm worth $450
Exterior/Suspension:
Standard Rims and Brand New 205/55/16 tyres.
Standard series 2 bodykit
Jun rear bar lip that looks really good and makes it stand out alot more then stock
Custom front lip
Custom Roof wing (very rare!!)
Xenon HID lights
Front Tein HR fully adjustable coilovers
Rear ISC fully adjustable coilovers
Brand new adjustable ISC camber arms
Brand new ISC Hicas lock bar
Brand new Gk-tech lock spacers
Brand new Adjustable Gk-tech rear toe arms
Brand new Gk-tech front castor arms
Brand new Gk-tech rear traction rods
Brand new Gk-tech rear subframe slip in collars
Brand new Adjustable front tie rod ends
I'm sure there are things that I have missed..
Car is serviced every 4000k's
Oil: Castrol Edge 10/60
Oil filter
Sparkplugs: NGK-R gap 0.8
Car will also come with standard Airbox
Rego till January 2nd 2013
PRICE: $8350
BUMP Will consider swaps and genuine offers this is one of the cheapest R33 series 2 available.
Only bad points about the car is the Guards were not done properly so the paint is now cracking.
Yep o agree the job was shocking , however was done by previous owner , just shows what happens when u cheap out :( I think its still reasonable considering the amount of work the car has.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
