lol iam 22 and i ment to say cam and a manual conversion and my buddy says i should get forged pistons and ported heads but hes a commy person
and for u losers given me shit i have dyslexia so what now?
Lol..... So you've repeated quite a few times?
Your buddy is a clown! The RB25DET NEO engine kicks ass and your diff probably spins 2 wheels so he is just jelly!
Manual = yes, if you can do it for the right price and do it properly
Cams = No, not yet as you could get better gains elsewhere.
  • Replies 45
Popular Days
Posted Images
TBH it may be smarter to sell the car you have and buy a manual..... At least then its a genuine manual car with no issues in terms of rego and stuff, also the conversion changes heaps but there are little bits like dash cluster and steering wheel etc that people overlook and they arent cheap. I would sell yours, use the $8k and buy a modified manual and you will be all sorted!
Auto sedans dont seem to hold their value...... Actually lately imports in general dont! Try 10k and see what response you get.... OR take the parts out and make it cheaper and put them in your new car
and guy what u giving him shit for he asked for your opinion? and i get what he was saying about the cam/manual con
i agree about the cam thats a later upgrade if u even need it
paint. its your car
bodykits i like sum but sum also look stupid as f**k
manual. yer but i would still go r34 parts so everything is good and prop
a sedans worth is anywere from 8 to 13 up to u were your car fits
AND I AGREE HOW TO U JOIN SAU CLUB LOL I WONT STICKERS
paint. its your car
Just for the lulz!
To join the club you need to find out who has the SA member forms and fill it in, pay your cash and your good to go! Joining SAU is well worth it!
In terms of performance mods, there is a route to take that is correct, and there is a route to take that belongs on Boostcruising.com, this thread was heading that way so i helped!
My car has NO kit, standard paint and thats it....... It does skids! So its good!
geeteetee u say this look stupid but u have eyelids :yucky: i am confused
so to sum it up if u wana go to auto salon YES street car NO
And if you want to increase your post count start a new post for every sentance :no:
Eyelids and bonnet lip = tough.....
Big front bar = aids
Guest
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
