  • Replies 45
Popular Days
Posted Images
  On 12/09/2012 at 6:19 AM, nissmore said:
there was a r34 from sau plates were dubstep lame plates but sweet as car
That was my mates 34. Pretty sure he sold that thing a while back.
Honestly mate, there are a lot of headaches when doing a manual conversion. The list will only grow bigger lol. Do yourself a favor and sell your current car (like most people have said) and get a 34 manual from factory.
That way you will be saving a whole lot of $$$
  On 12/09/2012 at 6:56 AM, RISk34 said:
LOL And if you want to increase your post count start a new post for every sentance :no: how u no
Wow........
Edit - Krishy hook these guys up with some membership forms too!
Closed for now - I don't have time to clean this thread at the moment (if another Mod/Admin comes by and does it, great).
If you don't agree with a thread or can't post something helpful/constructive - then quite simply - do not post. Not all users have brilliant spelling, grammar or otherwise. It's very confronting for new users to come on here and be accosted with the disgraceful attitude of some of you around here lately.
In particular it's a few of you NSW members that seem to think it's "ok" to follow each other around in threads and post utter dribble all over the place whilst derailing threads constantly. If it continues past this point there won't be warnings, there will simply be bans.
We've been nice enough on this and tried to give you guys hints to cut it out but you clearly aren't capable of doing it of your own accord.
Show a bit of respect for one another and pull your heads in.
Thanks.
OK nissmore .... I have done a bit of digging around, and sure enough it turns out that RISk34 is in fact YOU - how dumb do you think we are? So stop replying in your own thread using a different username, choose which of your personas I am going to delete, and grow up. Ash should we give him a holiday from the forums as well?
Guest
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
