After having some serious trans perfomance issues, it was found to be travelling in "safe mode" ie 3rd & reverse gear only
so I followed the recommendation of some SA forum members & took my baby to Michael @ MV Perfomance Automatics
...it required a shift solenoid set to fix the non-selecting gear problem & I agreed to a shift "improver kit" (quick shift) as well.
It cost $390 for the Shift Solenoid Set (that Nissans wanted almost $900 for) & $350 for the Shift Improver Kit + the trans fluid & gaskets etc $75.
Now I am a seriously OLD fella but far out, I can not believe the extraordinary difference in it's performance !!
it is frigg'n AWESOME !!!!.... it is a totally different car.
If you have not put a quick shift in your auto yet, do it ! It is the best $400 you will ever spend.
OLD Mark
  • Like 1
https://www.sau.com.au/forums/topic/409131-c34-auto-trans-quick-shift-kit/
living just 5 minutes down the road from MV, your giving me good reason to do this. Must say with most makes/models I have had with autos - MV has always been the first reference anyone has given - top guys.
Indeed Aaron...he does different "levels" of the shift kit ranging from softer gear changes to "slamming" into gear for high performance & drag cars.
I am OLD & just wanted the "softest" change....now there is immediate, no flarring changes & the box is immediately receptive to the increase & decrease
in revs...it is how it responds rather than the type of response that changes. HOWEVER, when I change over to manual control on the steering
wheel, it feels just like a manual box change...unreal !
It actually feels like I have a bigger turbo kicking it...the immediate gear change response is that good...all for $400
"the OLD fella"
Had one done in an RS a while ago and it blew my mind how it changed the car, better shifting into lock up mode when cruising and better oil flow to the back of the box. I wouldnt bother getting under the car for myself, Id go straight to MV.... as I intend to with the current RS$...lntentional typO
Hey guys
i live in syd but am very keen to get a quick
shift kit 4 my rs.seems like a cheap cost for massive
improvement.is there anyone that has had the kit put
in here in syd? Or know where to source the kit from?
Cheers boys
  • Like 1
  • 8 months later...
  • 3 weeks later...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
