  • Replies 72
Posted Images
So quite simple, who has the coolest numberplate, removing the (no doubt unstoppable) discussion on if having a personalised numberplate makes you a knob.
My plates read BCNR33. Got them with the car.
Saw BNR34T on an urban 4WD of some kind (Audi if I recall) the other night. lol'd.
Saw the plates FOMOCO on a Toyota Corolla today.
FOMOCO is the acronym commonly used for the Ford Motor Company, specifically their racing parts and muscle cars.
Edited by Amaru
Saw "BNR-33T" (nsw plate) on some kind of softroader. (pathfinder maybe???)
^^^I put this in the Plates that make you LOL thread.^^^
Coincidence ???
Flamin' Mongrels takin' all the good plates. NO FAIR !!!
Sinista's Plate is pretty damn fine as far as cool plates go.
Coincidence ???
hahaha as my post above, saw the same car :P
Was it 34T or 33T ?
Definately was NSW plates, but I can't be sure of model of car as I was still asleep on the way to work.
(dumbf**k o'clock)
I think it was redish ish in colour?? :blink: maybe...
regardless it was definately a WTF? moment. LOL.
Was it 34T or 33T ?
(dumbf**k o'clock)
It might be someone who used to own one and wants to keep the plates (for a future car maybe?) so has just chucked them on another car instead of paying to store them.
Wow, so BNR34T and BNR33T are both out there, being used on softroaders and not for their true purpose.
Makes baby Jesus cry. (he builds hotrods after all).
Tis a shame that these people do this and not pass em on but I guess a plate is just a plate.
A numberplate, by any other name, would smell as rich.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
