Hi all, I fitted my new large 2 piece tailshaft, along with 2nd hand 4.11 diff, I opened diff and cleaned etc, see shaft in the 'what tailshaft do you run' thread. I have a coppermix single clutch which gives gear noises at low revs as its got no damper, but at 120 it feels like being on the ripple things on the freeway, its terrible! The diff felt good and appeared ok when I cleaned it, but it got super hot (70 degrees ish) in under 10 kms driving. Please help I have a trackday in a week!
https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/
The people who made it need to balance it again or possibly the length has been measured incorrectly?
Also make sure your centre bearing is in its natural position.
/\ on the 2 piece the uni's need to be lined up, did it come bolted together?, still if the diff is getting hot may be binding somwhere?, if you need to get to the track maybe just get another diff, did you have the old tailshaft to try as a comparason?
No, my shaft was the donor for centre spigot and sliding spline, It was bolted together when they balanced it, and it was balanced to some crazy tolerance. And uni's were setup to within a thou of perfect. The centre bearing could be lowered 5mm to get shaft perfectly straight, but that shouldnt affect it.
Its very bizzare, I expected gearbox noises to resonate through it, but not a death vibe.
How could anything in the diff be causing this and how could it get so hot?
Its never been shimmed either..
I have my 4.36 diff which is lazy but will get me out of trouble. I will get a genuine good condition shaft sent out today incase it all turns to shit. This is pretty sad though...
How do you mean "lazy"?
Also, interesting on the gearbox noise... How much noise are you getting? Is it just a light sound? (sorry I know it doesn't help your problem but it's related to a similar convo I had this week)
It had been dropped in transit, small scratch mark on flange. But iv narrowed it down. Old diff back in, and its between 115 and 130 kmh. , its doing my head in, diff and box within well under 1 degree. Is a harmonic imbalance plausible?
After checking everything yet again, all angles are perfect, and the vibration is worse at diff end. I was told not a good idea to undo centre loint and fit factory rear half as its not balanced together, but they should both be balanced anyway so ill have to try it. Anyone got any further experience/input?
  • 3 weeks later...
So I had the shaft rebalanced again. This time far more accurately than before. Been running stock shaft, no issues at all. Put on new big one again, same vibration! Anyone got further ideas before I loose the plot??
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
