Hi All,
I need the wiring diag or quick explanation on the following.
Z32 afm into the RB20 loom, which colour wires do I join into??
GTR resistor pack to run the GTR injectors on an RB20, I have the GTR pack and injectors, just need to know where to splice.
Anyones help will be greatly appreciated and a christmas card at the end of the year!!!!
Cheers,
ken
https://www.sau.com.au/forums/topic/40915-z32-afm-rb20-loom-gtr-resistor-pack/
The factory ecu has 6 pin outs, one per injector and one common ground.
To wire in the low imp injectors and dropping resistor you need to splice into the ground wire at each injector plug and run them to the 6 individual plugs on the dropping resistor. Then run the common ground wire on the resistor back to the point in the gtst loom where the 6 wires tie back into one and run back to the ecu injector ground pin.
To find the common pin on the gtr dropping resistor just check for continuity between all the pins with a multimeter to be sure as i haven't seen one for a while and can't remeber if the 6 go in one side and the common comes out the other.
Pretty simple in theory but a pain in the arse when you are pulling tape off looms to find the right wires :D
Sorry mate, can't remember the the colours in the loom, just remeber there is a common ground running into the ecu cos i recently wired in an emanage. best bet is to strip the injector harness and trace the wires i'm afraid.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
