Hi guys, I know this has been discussed in a few thread before, I'd just like some help identifying something.
Occassionally I get a high pitched squeal or whine from somewhere under the bonnet, hardly happens, I found downshifting into third or second and giving the car a bit of juice in high rev (3500 - 4000 rpm) and full boost makes the noise last for a second or so.
It's quite hard to replicate. Anyway from a few threads I have read people are recommending checking the turbo exhaust manifold etc for loose bolts and such.
I've taken off the turbo heat shield and not sure what to check. Most of the bolts were pretty tight already, I did notice that there was a bolt missing on the manifold and I'm not sure if there was an existing bolt there or not? Anyway I half screwed in a bolt in there to see, took the car for a spin, couldn't get the car to re-create the noise however I didn't notice a small chirp in second gear that may have been it starting.
Anyway, see the pic below. Is there anything in the pic I need to check, and should there be a bolt in the spot I marked?
that bolt is nothing...it just holds the heat shield on
when mine started squealing it was the bolts that hold the turbo to the manifold (the one you can see in your picture actually as well as another one)...I tightened it with my hand and it was good again for a bit...
just feel around the turbo and manifold bolts to see if any are loose...
Had a mates car do that and it was a tiny split in a cooler hose (was the elbow under the turbo from
Memory) it would only do it under full boost and the split was really hard to find.... Long shot but I you don't find the other issues then it's worth a look :)
  • 3 weeks later...
Mine did this a while back, ended up being a intake gasket..
sorry, was that the gasket between intake manifold and the engine head or the gasket between the parts of the manifold itself? pardon my English, I'm from Russia))
Squealing is from tight or loose belts African Americanachi. Have a good feel of your visible belts. Maybe lay of the maccas. It could be your wife complaining. Mine does. Its a high pitched squeal the whole way there until her fat cake hole get filled. Nah kidding, she is a beautiful 5"10' 26 yro bitch! Or loosen your cam belt. But dont do that cos you dont know what the f**k you are doing.
same problem for a while things ive checked on inlet side cos that's where its coming from.the noise starts at about 7psi
manifold gasket.
disconnected factory boost gauge sender.
checked intercooler joiners for pin holes.
checked hoses for splits as this has happen be for to me.
even had a smoke test twice.
the only thing left for me is the pvc valve and hoses to the pvc
its a split hose some where i think cos it needs some psi be for forced open and whistle
epic post +1 Like
I had pretty much the same problem as you have. I had checked all the gaskets and still could not find the leak. It was also happening at 7psi and above. I had replaced all my vac hoses & all new clamps. Finnally I made this up and found the leak in about 5 mins.
Remove your intake from the front of the turbo, Attach the hose with valve to the front of the turbo, pump up using compressor. (no more than 10 psi) You should be able to hear the leak.
(Engine off, It will not hold pressure long. Just enough to find the leak)
Parts used to make this are
1 right angled silicone pipe from old stock intercooler pipes (or from any auto store)
1 screw in tyre valve
2 hose clamps
1 plastic pvc end cap (bought from a plumbimg store)
Edited by newboost
  • 6 months later...
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
