Hey all,
Not sure if this belongs in the drivetrain section or here but I thought because changing diff oil is general maintenance here would work.
I am going to do my gearbox and diff oil and while looking on here for suggestions for what oils to use I came across a few threads saying there was a difference in the LSD's for series 1 and 2 for the R34 GTT's.
I thought they all had helical LSD but a couple of threads I came across said the series 1 had a viscous LSD.
So confused right now as I am finding conflicting information.
I guess I really have 2 questions.
1. Can anyone confirm if a 1999 manual R34 GTT uses a helical or viscous LSD?
2. What would be the best oils to use for each diff?
I was going to use Motul Gear 300 for moth gearbox and diff but I
l'll hold off on buying as much as I was going to if the diff needs a different oil.
Cheers,
Andy
Edited by azathoth
https://www.sau.com.au/forums/topic/409211-1999-r34-gtt-diff-questions/
A series 1 GTT has a Viscous diff. Only the series 2 manuals came out with the Helical diff's.
The series 2 auto's also used a Viscous diff.
From memory i used Nulon 85W-140 limited slip diff oil in my series 1 last year.
Edited by B-Boi34
  • 6 months later...
how to tell the difference between viscous an helical?
I've been told that if you turn one wheel, the other should turn in the opposite direction (shits fkd up I know). Haven't tried it for myself though.
  • 5 weeks later...
From memory the Helical will act like an open diff, so if you turn one wheel the other will turn the opposite direction. If you turn the wheels on a viscous diff they should turn the same direction. I also have not tested this theory.
The other way is check the code on the diff, a viscous is a R200V I think
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
