hey guys had a leaking injector that i pulled out today. going to replace all the o rings on them. 2 questions. should i do anything more then just replace the o ring to stop leaking ive heard they leak alot. and can anyone confirm the size of my injectors. numbers i found on the injector are:
jecs
A46-000001
5L31 2827
injectors are in a rb20det
Cheers Adam
Edited by boardman
jecs
A46-000001
5L31 2827
Cheers Adam
I think I've got a couple of dozen laying around if you want some. You can have them
Never mind I just read your info haha. Ill try these seals out first and see how they go if it is the injector we will organise postage and stuff. Should I be putting anything extra on it to seal it up like silicone or just the o ring.
Rubber grease the oring on top but not on the bottom of the injector. Reuse the spacer at the top.
If you don't have rubber grease, vasoline works also.
Buy the orings from Nissan. Non genuine ones aren't the same size always
i replaced the o rings today couldnt get genuine ones from nissan but went to a injector place and he gave me 6 new ones. put them in and the same injector is still leaking. looks like its the actual injector that is leaking not the seal so i will need a new injector. Daniel ill pm you and see what we can sort out cheers
There is no hose going into it. That's Rb30.
Mate, pretty sure I can get them to you for $15 freight or wherever you are.
I'll clear my messages so you can try sending me your address
yep, sorry you are correct, the 30E is top fed hose and the 20DET rail sits right on top of the injector with a rubber seal
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
