So the time has come to let my project go, have spent time and money and need to let it go in favor of other pursuits.
car made 160rmkw and 450nm @14psi could easly make more as running rich on top end so retune will fix it up, currently removed boost tee for roady and is running stock 12, still bloody quick.
Pics pending will be up shortly. Asking price, negotiable ,$14,000, just a rough estimate based off what i saw on carsales without roadies.
mods listing
engine: rb20det (out of r32)
rb20 box
rs yamamoto chiped ecu
locked 4.33 diff
hight flowed r33 turbo
52mm radiator
twin el thurmo fans
fmic
3" turbo back exhuast with twin pipe magnaflow muffler and high flow cat
bosch 040 fuel pump
catch can
gfb boost tap
new water pump timing belt power steering pump and all belts.
new welsh plugs and rear main
pbr heavy duty clutch.
new clutch master and slave
suspention and brakes:
5 stud conversion
r32 calipers all round
new pads and roters all round
new brake master cylinder
new bc coilovers
new jic front caster arms
new jic rear camber arms
new (not fitted) gk tech rear toe arms
new (also not fitted) tie rod ends
front and rear top strut braces
new soft brake lines
interior:
blue dildo shifter
drift wheel
drift button
r33 4 door front seats
dash mat
apexi turbo timer
sparco boost guage
tacho does not work
sound:
very good pineer head unit
new pioneer front splits
j-car rear splits
jbl 12" sub
j-car monoblock amp
exterior:
HID low beams
white led packers
window visors
roof wing
latle model chrome grill
17" work rims 8" front 9" rear. (paint on wheels pealing, need referb)
also have a set of stock 16" r33 wheels, depending on price will judge what will be on the car.
clear front indicators (not pictured)
autech side skirts (not pictured)
rolled rear guards
few bad points:
mainifold to turbo gaskit leaking a little
bonnet is a bit demaged with dints and paint flacking
rear qtr has a few small dints (about 5 of them the size or a 10 cent coin)
open to offers or possably swaps with cash my way depending on my circumstances as their currently constantly evolving. 17 inch wheels may not come with the car to drop the price a bit more depending on buyer.
any questions call Josef on 0431 625 850
  • 1 month later...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
