You guys suck man..
How's this poor kid supposed to tell his homies he's Rollin on 20s if he's got 18inch wheels..
Its all bout respect in da hood where the only form and function that matters is a dole form and a functioning bong...
  • Replies 49
You guys suck man..
Easy, put a 20" chrome badge on the gaurd next to the wheel arch. Spankers can't read a tape measure, so they'll never know they're being lied to.
Thanks to all the replies, except these 2 d&*ks. I am not a "spanker" or "a kid", don't live in the hood and can read a tape measure just fine. You guys sound like you are lacking in manners. I would gladly put some into you. Go comment on you tube videos, instead of posts where people would like genuine advice.
Lol smart ass
Seriously though if you keep it to an 18 inch with a 35 profile it keeps your rolling diameter just under the legal limit so your speedo isn't thrown out..
And for those who say cops don't check.. Believe me they check, I now have a wheel chart in my glove box
Lol smart ass
A long while ago when I got breath tested in the 34 the cops got all excited and run over with a lap top, after a while they said I was good to go, I assume their legal sizes etc were on it? They only checked the rears (265/35/18).... Anyway, 18's look and perform well.... That's still my suggestion :)
cheers mate, you've been nothing but helpful. Thanks :) Only have an attitude with people like those guys. lol at the wheel chart, take it you've had a few run ins. I'm only thinking of the 20's as another look, not looking for track use out of them. Have access to a cheap set. Just thought I'd push the boundaries and see how I went. Cheers
My spare 17s that looked s@@tty az on my car look good on my mates 32, so it also depends on models... Is this for 32 or 33? Title says 32 but I thought I saw 33 somewhere?
Ah yea bud, it's for a 32. I'm importing my 33 so they'll probably end up on them at some point.
18s will look huge on a 32 :) but I would be wary of the boys in blue still.....
twat.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
