I noticed my car charges badly, and worse when it is warmed up.
So i pulled the alternator out for a look, and found a hole in one of the brushes. Normally i wouldnt care but its right where it contacts.
Anyone know if this is the problem?
Should i grind it back? Or get a new one?
I need to get it charging properly again.
Ideas anyone?
I highly doubt this is your fault but need to see the commutator (what the brushes run on) to see if it's arcing or getting a good connection. I would file it down a touch if your concerned as its longer than the other anyway but I doubt I'd file it myself.
I've got part no for brushes from ashdowns I can grab later for you or you can order generic ones on eBay if you get measurements. I had trouble first time I wanted them
What do you mean it doesn't charge well? Low voltage or low current output? Or light flashes?
Edit- if you haven't assembled an alternator like this before you push the brushes in all the way and insert something small like a 1mm drill bit through the hole in the back to hold them in place while the 2 halves are put back together. Just be gentle so the brushes don't break into pieces
Edited by t_revz
Thanks for tracking part number, its a weird setup with the brushes sort of sealed in a box, dunno if i can dissasemble without breaking it.
old plastic makes it brittle too.
doesent charge well indicated by bloke who sold battery to me.
Have put a temporary volt meter from cig lighter and it shows 13.9 when cold, then gradually drops to 13.
Switching all my gadgets on or off makes only about 0.2v-0.3v difference.
The light doesent come on, but the manual says 13.9v-14.9, although thats a GTR manual.
Shows 2.5 ohms across the commutators, ok right?
Anyway ill clean everything, put it back and see how it goes, might spray the outside coil with clear just in case its shorting.
I wont file it as it may take ages to become flush again.
Drill bit, yes, thankyou, good idea.
Edited by D.I.Y. Mik
Yes the regulator/ brush box can be Disassembled just try not to break it if you do.
13.8-14.4 is better but a bit each way is ok. If your not having start dramas I wouldn't be too concerned in case it's the location of your gauge making the voltage seem lower.
Brx40710 is for a 10 pack of brushes but wouldn't recommend doing them if you haven't before. Bit fiddly and have to solder quickly so heat from iron doesn't heat regulator components too much.
Slap it back together or take it to an auto sparky to do brushes and new bearings
Edit- cant really check commutator with a multimeter correctly. Really need to check current draw but it sounds ok
Edited by t_revz
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
