They are cheap, and nasty, but with a bit of die grinding, and re-machining of the flanges perhaps(they are only linished by the looks of it) they can be a good option for guys on a budget.
I had to modify the wastegate path on one I had here, as it was going to hit the dump, but it all bolted up fine. Messy mig weld on the inside of the merge was a bit... :/
Mine was also pretty good quality with the collector being pretty clean inside, only complaint I've got is, the 4 bolt flange one of the holes is off centre so it makes it hard 2 slide a turbo over the studs or a gasket 4 that matter :(
Edited by methz
  • 2 years later...
On 8/24/2016 at 10:19 AM, Ke55pig said:
So after four years about 20 track days and 10 thousand st ks my hyprid has crumbly cracked welds in the collector no one wants to fix it so time to buy  six boost
that seems like a good value . $600 for 4 years
16 minutes ago, Dose Pipe Sutututu said:
twin scroll manifold.. then one day get a better turbo :)
Theres no real gains or point for  twin scroll if not using a twin scroll turbo ??
26 minutes ago, zebra said:
I would have thrown the manifold through his front window if that happened to me
or weld it to a gearbox and put on the door step.
Funnily enough, i contacted hybrid at the start of the week about their low mount manifold, as they're fairly cheap.
I asked about warranty for cracks, re surfacing and warping. They dodged the warranty question but mentioned they have never had a single manifold crack. Send them these pictures. I'm sure it won't be the first ones they've seen though :ninja:
Thanks to dose mang, i am now going to go through havoc performance.
Touch wood - mine has given zero problems over a few years of track only use.  I expect it will stay that way.
Have to check my race diary but about 12 events consisting of practice day then 2 race days for the weekend.  A bit more demanding than a typical half day event offering 4-5 sessions.
However - I did not just unpack and then bolt on.  Spent about 2 hours with die grinder and grit blasted the hand finished result.  Then had it ceramic coated.  It has proven fit for purpose and application at the power level I'm running.
Any of these fabricated manifolds "should" be checked and given some finishing if warranted.  It's a matter of observing due diligence and preparing things for reliability.
I'm certain that there's some far better manifolds out there, simply that the user pays for the prep and finishing.
My ETM 1jz  manifold is perfect.
If I ever build another turbo car I'd never use a cheap manifold. I have in the past and found they are aweful.
Compare the collector / merge of a good manifold to the ones above and you can see what you pay for.
Prep and finish should be done by the manufacturer no matter how cheap the manifold is. 5 minutes with a die grinder might make it look ok. But shit welds will still crack and break off and destroy shit.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
