So something that I've recently been questioning is why many results of the 7's in "RB26 turbo upgrade, all dyno results" thread are the way they are.
I'm lead to believe that these are the most responsive turbos of the bunch when comparing against the -9, -5 and -10. Quite certain that most people who
have these turbos are reaching full boost quite a bit earlier than 4,000rpm; if anything, probably closer to the 3,500rpm mark?
Which makes me wonder, why are the below dyno sheets showing full boost at such high rpm? Some are as late as the 5,000rpm mark, wtf?
I understand that dyno graphs and real world may differ, is that what's responsible for my misinterpretation?
Would be great if the owners of the cars below could have a say in this as they would most likely know whether or not the dyno graph is a reflection of the real
world boost curve. Anybody with a similar setup is also most welcome to provide some feedback.
300wKw at 20psi on 98RON
R34 GT-R V-Spec II
* -7 Turbos
* 700cc Denso Inj
* Power FC D-Jetro
* Blitz front pipe
* K & N Panel filter
* Greddy DSBC
* Tomei Poncams 260/10.25
* Tomei Cam Gears
* Bosch 044 fuel pump
* Nismo 3" Exhaust
* Hi Flo Cat
Unopened RB26DETT
Stock cams
HKS Cam gears (inlet at 0 Exhaust retarded 2 degrees)
-7 turbos
TOMEI s/s dump pipes
3.5" do luck exhaust
Trust 100mm fmic
walbro fuel pump
stock fuel reg
Sard 700cc injectors
Power-FC D'jetro
398.3hp at all 4 hubs @ 1.2bar
99 R34 GTR non-vspec
Unopened engine. Done approx 70K.
100K service done with all OEM parts, including water pump, timing belt, bearings and seals.
Adjust Cam gears
Garrett -7s
Stock injector
Stock fuel pump
Stock air box with high flow air filter
Stock intercooler with full HKS hard piping
Nismo fuel regulator
Spitfire Coilpacks
Iridium spark plugs
EVC 5 boost control
Power FC
Stock dumps and manifolds
Full NISMO WELDINA NE-1 Exhaust De-Cat
Koyo Radiator
EXEDY hyper multi twin plate clutch
Tuned @ Racepace
Pulled 288.7 RWKW @ 18.2 psi, on BP 98.
Bought Sard 700cc and Bosch 044, but told no need to install them as I had -7 only. Stock injectors cycle duty @ 98.8%. Knocking rarely exceeds 25 under the sun. Feels hell a lot better to drive.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=322462
Updated in BOLD
1995 R33 GTR
Performance list:
garrett 2860 -7 running 20psi drops to 19psi
tomei dump pipes
trust front pipe
ballistic cat
nismo catback
1000cc injectors
splitfire coilpacks
bosch 044 fuel pump
haltech platinum pro (mafless tune)
bp ultimate 98
115 Greddy front mount intercooler and piping kit
Greddy air intake kit
280awkw at 19psi
Now 310awkw
There are many factors that will influence what your talking about
-health of engine
-how the dyno is set up
- restrictions in exhaust
- aggressiveness of the tune
These are to name just a few
my old gtr had -7's with all the fruit made about 300rwkw and the dyno sheet shows it making full boost at 4800rpm, on the street it definetly feels much sooner then that !
GTR_JOEY:
I agree on all accounts, however the specific graphs I've chosen mainly consist of quite well known workshops which have (I assume - probably shouldn't) relatively honestly setup dyno's. Correction factor will take into account ambient temp and altitude? These setups seemed to have relatively decent exhausts.
SiR_RB:
How much sooner are we talking? 4,000rpm? Below 4,000rpm? Have you ever loaded it up in 4th gear and had a look? I'm quite happy with the idea of 300kw-330kw.
My friend's r34 gtr was already quite quick at 318rwkw tuned by racepace. Mine being 5 speed 4.11FD in an R33 GTR may not feel quite the same, but I'm hoping some weight reduction and mild increase in displacement (86.5mm built motor) would negate the difference of the 6 speed
-health of engine
Exactly. I was driving a mates GTR with -7s not 7 days ago.
I can tell you now by 3300rpm it was well and truly game on where my -5s were ~4000-4200rpm. -9s are about 3400-3500rpm.
Yet when you dyno the cars, the graphs come on & look very similar (nowhere near 800rpm), due to ramp rates and other factors.
Why is it that they have set the ramp rates to make full boost look like its coming on later than it is?
You say that they are well and truly on by around 3300rpm. I take that as the perfect world situation on
a stock motor with all the correct supporting parts.
In the event that you run these turbos with a mild built motor for example with:
86.5mm cp 9.0:1
Light h beams
0.9-1.1mm Thin metal head gasket to keep comp high
Light head work to clean ports and improve entry and exit velocity
A GOOD TUNE
would it be reasonable enough to say that these turbos are likely
to come on even earlier, say around the 3000rpm mark?
-7s coming on by around 3000rpm mark (probably e85 or well sort out
motor) making power to 8000rpm would really be something impressive
I think. Sure it might be short of 350kw atw but a solid powerband of 5000rpm
is not something to be laughed at
-7s will nose over well before 8000 rpm
At the end of the day -7s aren't going to flow much more then 300rwkw and these days that isn't alot of power anyway
Would still be a reasonably quick street car no denying that..
I would find it boring though
86.5mm cp 9.0:1
Light h beams
A GOOD TUNE
When I say "on", you aren't making "full boost" - given such a term is silly. Is "full boost" 5psi or 50?
By 3300rpm the torque is coming on and boost is really driving so at a stab maybe 10psi which is 10psi more than a set of -5s would at the same RPM.
Every setup varies but i think 3000rpm for them to be really moving is a bit of an impossibility.
Despite small increase in displacement, e85 and some headwork?
I understand that stands true for an unopened motor on with 98 but with the above changes?
Edited by RB2600
Fair enough, I was having a look at the build of the old Advan R32 GTR and have just accepted that I won't get it to that type of response.
According to Russ, 3500rpm and the power was already over 300kw with a peak of 380kw-400kw depending on temps. Although it quite an extensive build,
I still wonder..really?
Starting to lean towards the -9 if they're only 100-200rpm behind..
You would need to spend big cash to get that sorta power and response
Ie
Big compression
Stroker
E85
380-400rwkw on -7s is pretty out there
Edited by GTR_JOEY
hi Roy
i will try and tell you what we have found really important and our mods.
power is approx 380 to 400 kw's @all four depending on weather and temp.
so yep, still 2.6 bore size, 270 cams tomei, adj cam gears, cleaned up cylinder head ports, n1 valve springs,cp pistons, tomei rods, n1 oil pump with reinmax gears(also use tomei oil pump previously), hi octane racing large sump (will be going to a hi octane racing 4 stage dry sump in a month or so) standard exhaust and intake manifolds, are intercooler, n1 garret equivelant turbo's, greddy intake boost pipes, apexi airfilters, autronic ecu and cdi ignition,gonzo exhaust, vp109 fuel( good for 30kw's and much safer than pump fuel), tilton brake pedal box, australian spec tein suspension, bosch fuel pumps, advan suge tank, npc clutch ( i swear by it!!), carbon tailshaft. block and crankshaft are standard, acl race bearings, 25 row oil cooler, standard blow off valves. we also run a water sprayer for the radiator and oil cooler for longer circuit runs.
we have tried hard to make the power come on hard down low in the rev range , which makes it easier to drive, we tried aftermarket extractors and the car made more power but we lost over 500 rpm before boost would come on so we went back to standard manifolds, adjust cams to get power as early as possible, car has over 300 kw's at 3500 all the way to rev cut, rev cut we have lowered to 7800 till we get a dry sump.
the other thing we have spent a lot of time on is the 4wd system and wheel alignment setup, nearly all r32 gtr 4wd drive systems we have looked at including our car when we got it, do not function as they should. wheel alignments also have been a real issue. we have had a lot of trouble get alinment shops to align to the spec you ask for and ahen checked they are way out!! we now do all our wheel alignments by string line and have had far better results.
the car will be coming off the road in two months(after nsw dutton and maryborough sprints) for a full rebuild, dry sump if not before) , side exit exhuast for events that allow it, chromoly strut to strut cage, try to lighten it some, total repaint, stack dash , hopefully carbon doors, bigger swaybars & a few other changes.
hope this helps if you want to anything specific just ask
cheers russ
Not a stroker, but a damn good motor lol
HAS he ruled out a stroker??
Not trying to argue with you but he just says "standard bore size" which obviously leaves the door open for a longer stroke size??
It's pretty amazing power if it is all standard but seems to be pretty solid power with fairly standard upgrades and -7's.
I was assuming it was not stroked considering he mentions "standard bore size, standard crank" but now that I look at it, he does mention Tomei rods, so they're possibly the 119.5mm centre to centre model?
Which would effectively increase stroke to 77.7mm?
Bleh...slightly off topic, but I found a lovely crack in the block...guess I won't be thinking about turbos anytime soon...
the crack is actually worse than it looks in this photo :(
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
