Hi guys came across a couple of articles when I was in Japan about the tuners there using gtr airflow meters as a upgrade on earlier gtr's 32,33 and 34 and also on SR's
most tuners were quoting better response, no stalling and more power in some cases got me keen to try one out on my car
also these sensor are easily replaceable and cheaply (compared to z32 afm at $395) to buy as you can get just then sensor itself
they can also be fitted to alloy piping easily and be fitted on the hot side if required
I sourced one from Japan but ended up selling it to the nisstune guys and making up my own kits
I contact the guys at nisstune to help me out with getting it tuned and they were keen as
they got a vq map to suit and can now tune any nisstune to suit the 35 air flow meters
below is the results for my car it feels better response wise alot more linear and no ldle down stalling smile.png))))))))))))))))))))))))))
in z32 airflow meter size piping (i.e 80mm) they do top out around 300rwkw above that you would order it to suit bigger piping
my car had had z32 550cc sards and nisstune so pre tuned but my tuner reviewed it and made a couple of small changes
now has 35 afm 550cc sards and nisstune and retune to suit same dyno same boost level used for both runs
will be testing with my mate the bigger pipe size ones on his 380rwkw rb25 r32
then once test can supply those to
contact me via pm if you keen as I bought a few test examples to try out
ps I just like trying out the new tings there doing in Japan to see why there keen
pricing is way under a new z32 and I'm selling the extra ones I got off as complete replacement units so afm pipe plug
super keen to try these out on a gtr if I get enough interest I'll make some more kits up
Edited by R31Nismoid
A Z32 maxes out @ 300rwkw in stock piping? Since when? First I've heard of this and plenty of people have made well beyond that.
From your graph results, it just looks like the dyno has been done with a different ramp rate rather than any actual improvement. I find it hard to believe just a AFM/air sensor swap would give you an extra 40rwkw @ 3500rpm.
Do you have the original print out of the blue run, before it was overlayed?
The three cited factors ie. easier packaging/install into existing/custom pipes; and price sound like compelling reasons to give one a try if running an AFM setup. Eliminating stalling would be a significant improvement as anyone who's gone through that saga would testify.
It is only a sensor that measures airflow, so provided the fuel mapping is correct and the AFR in desirable range, difficult to see ANY reason why there would be more more torque at any given rpm UNLESS total airflow (boost) is changed. Before/after graph overlays please, as above comment by Jez.
my post say's in z32 pipe size ie 80mm the gtr afm do max out at 300rwkw
so if you want over 300rwkw in single afm application you would stepup the pipe size as they do with gtr's
there say power on the Japanese website I guess from less restriction however
I wasn't expecting more power and you wouldn't do the swap for that reason but for all the other reasons are
I posted the dyno cause everyone would have asked otherwise
vct was working ramp rate I assumed was the same guess not
however as said I didn't care about the power I cared how it drove (alot better smoother) and didn't stall afterwards
check out yashio factory and hpi's japanese websites both big name japanese tuners do these upgrades now to both gtr's and sr
it did it as I was keen to try out something new out of Japan interesting neither the less and you can thank me later for putting my $ up as a test run
boost was the same on both runs as stated and nisstune took that graph for his records
here's 2 graph's that I found not sure its what your after shows boost
Edited by 1400r
sensors gen nissan is around $200
can get cheaper copy sensors but untest who knows what you'll end up with
my leftovers with tested sensors I'll sell each one for $250
full kit pipe plug sensor and wire diagram
And i said that it doesn't.
The sensor in stock Z32 80mm housing will have the resolution for over 300rwkw in singular form.
GTR AFM's are not 80mm. Nismo replacements which are similar to a Z32 also do not have issues @ 300rwkw given you have two of them. So again not sure what you are trying to get at because the results clearly show otherwise in almost every single instance. I've never seen anyone max a Z32 @ 300rwkw in 80mm form.
AFMs are not a restriction. So again - guessing isn't good enough.
So it just sounds like you had a poor setup prior? Be that tune of AFM.
I've had various AFM setups (factory & custom) for years and never had any stalling issues to speak of. Stalling comes down the tuner ability & also the AFM position. Unfortunately a lot of people get the AFM position wrong and then blame the AFM when it's actually their own fault for putting it too close to the turbo inlet and the reverb causes issues.
again read my post
in z32 pipe size a 35 GTR AFM WILL MAX OUT AT 300 rwkw
nothing to do with a z32 apart the pipe is the same size making it a swap over
how many 600rwkw 35 gtr's have you seen with stock piping and afm's?
how many over 300rwkw z33 with stock piping and stock afm have you seen
Ive miss written my first post or you've miss read it
I don't need to guess but I did for you as I'm not saying it'll make power yashio hpi do go argue with them
my tuner i.e Pete from Nisstune(heard of them?) said every sr he's seen with a z32 doesn't run 100%
regardless of who tuned it especially if your running it in front of a big turbo
these afm have no reverb issues
have had idle/stall issues with 3 different tuned by z32 sr combos
Edited by 1400r
not sure what a +
is mate afm was in factory position in front of a t28 2 tune's
and in front of a 2835 in factory spot with the other applications tune's
your all missing all the postive points and just looking at the power
replacement cost new z32 is $395
hot pipe fitment ease ahlar map style if you pop a hot side cooler pipe
response/smoother
no stalling
again read my post
Right so in one line you are saying this:
A R35 GTR AFM into a Z32 housing, that then maxes out @ 300rwkw.
So in effect you are taking a step back because the original Z32 would flow more than 300rwkw. :huh:
response/smoother
no stalling
From the pictures your original AFM is far too close to the turbo inlet so it comes as little surprise you have driveability problems.
I know people with SR's under 300rwkw and AFMs and none of them have any of the issues you are talking about.
This is all just sounding like you had a setup with issues and you've simply fixed them in a round-a-bout type of way rather than their actually being any real gains, aside from the very strange dyno results. Could perhaps be the tune was given more attention as well.
I fitted one of these to see what the fuss was about no other reason
35 gtr's run 80mm piping factory it just happen's to match the size of a z32
what do you do when a z32 maxes out?
with a 35 gtr afm you just fit a bigger pipe
in terms of only outright power reading ability in a 80mm pipe yes a step backwards
however upsize the pipe diameter (same as the do with 35 gtr's) and no problem reading higher
in terms of cost, replacement ease etc there still a step forward
the afm is in the stock postion
fact is 35 gtr afm has no problem there z32 does
you need to look at it this way if you were setting a car up you'd go these in whatever pipe size you needed to read correctly your output
rather than using z32's now
you wouldn't pull your z32's off if your not having stalling issues like all the sr guys are
unless your z32 shat itself or something
Edited by 1400r
http://www.yashiofactory.co.jp/
http://www1.ocn.ne.jp/~p-craft/
http://www010.upp.so-net.ne.jp/rio/
http://tsugio-blog.com/?day=20110822
http://apmshop.ocnk.net/product/1
http://www1.ocn.ne.j...-craft/top.html
finding all these was reason enough for me to wanna try them out
"We will divert the air flow meter of your suggestions 35GTR from this year.
I had been testing the demo car at 34 because it was anxious from people before.
Although it takes a little time so we have also tested various types of engines in other vehicles as well, I was also able to take various data.
Airflow specification, I think I can come and have another consultation embarrassed person or stall the airflow, such as trouble in RB26.
I think that there is no downside as listed, such as Rev G Maga.
I will come to quite different, such as smooth rise of low-and medium-speed rotation torque is also up more than 34 of the demo car, even until now, I have happily low-speed torque is even more easy to get out of the normal 34.
I think cost is the initial investment it takes to become absolutely necessary adapting the computer when the air flow of the 35R, the benefits of the way, it's just that there.
I might change it as great over a little.
Please call the world is anxious."
Edited by 1400r
So they will bolt onto any size pipe and handle over 300rwkw and is cheaper than a Z32. Next question, how hard is it to get it to work with power fc, I'm guessing not to bad just a matter of playing with the settings, but have no idea how to do this
Would be interested if my Z32 decides to die so I can do a full 4" intake
Once you have an airflow map for it, it'd be a piece of cake to setup with a PFC. Getting the map would be the hard part.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
