Most I have seen (in aus) in a z32, with single z32 afm was 330kw, which maxed out afm voltage.
Heard a rumor that running te afm backwards can increase power and response as it doubles the max voltage ;)
Please tell everyone how that works?
I think this is the key (a2zed has built more vg's than anyone)
I have seen 1 300zx with the maf fitted backwards, it ran terrible, was ok at idle and wot, cruise was all over the place.
I would run 2 mafs on everything if I was given a choice. Sure they might not be a restriction up to 500hp, but the better the free flow of air supply is, the better the engine performs. Peak hp counts for squat, it is how it gets there that matters. A single maf may make 500hp ok on the dyno but when was the last time you raced a dyno at the traffic light GP.
I know for a fact a single Z32 AFM is good to 330-350rwkw. Only thing i would replace it with would maybe be a ford Lightning MAF.
whats your point? this isn't a thread for people running a z32 afm on there z32's
this is about people who fit z32 afm's to other cars and have some idle/stalling issues with 35 afm seeming to be the solution for Japanese tuners
if z32's had issues running z32 afm's nissan would have failed hard with that car........................
Wow. Defensive much? His comment was abotu how much a NORMAL Z32 AFM was good for, and so what sort of sense (or lack thereof) was contained in the claimed possible power rating of the R35 in 4" pipe.
I shake my head sometimes. Seriously.
Exactly. Couldn't have said it better myself.
I must be missing what your both trying to say?
I can only guess your saying there's no point going 35 afm cause z32 is capable of reading higher output in 3 inch?
missing the whole reversion issue that some people have cause with "your" setup your not having issues one car because it's a frign z32
http://forum.r31skylineclub.com/index.php?topic=155168.0
might be time to close the thread again lol
Edited by 1400r
they have nothing to do with each other being a completely different sensor so knowing what one will do wont help with the other
testing will result in the answer you could probably calculate it from what voltage the 35 was seeing at 310rwkw in the 4 inch pipe
same as you could probably calculate it from what it is able to read in 3 inch setup inch (runs out of voltage around 300rwkw)
will post these results if I can be bothered getting them
Edited by 1400r
That is just wrong and you know it. Start with what is known. The Z32 is in a 3" pipe and can measure 300=rwkW. The R35 starts out in a pipe that is smaller than 4" and can measure heaps of power (flow) - by your own first post, about 300 rwkW. Put that into a 4" pipe and it should be able to measure at least 500 rwkW.
/rocket surgery again!
ok you know it'll do 500rwkw without know what voltage it was seeing in a 4 inch pipe cool
me I'd like to know or atleast have an idea of the voltage/talk to the tuner otherwise people on here will just say again the test was wrong
you might get away with saying it'll do 500rwkw on here I wouldn't
If you want to sell them, it might be in your best interests...
mate I honestly don't give a shit anymore I was trying to sell extra units I bought for testing it was never to make money just try to help recover my
dyno costs for test them out
Edited by 1400r
Are you a retard?
These things are a velocity measuring device. If they were not installed in a car, they would be called by their correct name, which is "Hot Wire Anemometer". Google/wiki it.
If you put one of these devices into a 2" pipe and flow air over it at 50 m/s, you will get EXACTLY** the same voltage as if it was installed in a 3" or 4" or 22" pipe with the same air flow velocity. So whilst the velocity would be the same and the voltage would be the same, the actual mass flow of air would be increasing with the square of the pipe size.
*it is necessary to point out here that we need to exclude entrance and exit effects, so we'd either want to have the flow well conditioned or use a sufficiently long piece of pipe to allow the flow to smooth right out.
On that basis, if you were to tell me that an R35 AFM maxed out with 5v at 300 rwkW in a 3" pipe, then asked me what it would max out at in a 5" pipe, I would have absolutely no problem telling you that the ratio would be about (5^2 / 3^2) and so the max power it could meter in a 5" pipe would be about 830 rwkW.
Whatever the actual limits in terms of power/flow/voltage are in a 3" pipe, you could scale them to get what they'd come out to in any other size pipe and you would be close to the mark. There's sure to be some lack of correctness because the actual original installation is not in a nice smooth flow and does have entrance/exit effects, and these would possibly be even worse in a larger diameter pipe - but at least they'd probably all affect it in the same direction away from the "ideal" case.
  • 4 months later...
Can anyone tell me who stocks the R35 AFM plugs? I have a good source of AFM's, but not the plug.
Also anyone got a pin out for the R35 AFM?
http://www.rhdjapan.com/hpi-r35-airflow-meter-harness-69542
http://nistune.com/docs/MAF_and_Consult_pinouts.pdf
I will search again but my understanding of a mass air flow sensor is measuring air temperature from which density is known . I think the only difference the size of the duct makes to the sensor is that more flow equals more air to affect the cooling at the heated wire . It's the regulated current required to keep the element at a set temperature that gives the sensor output voltage . From memory the circuitry is known as a Wheatstone Bridge and there should be info out there on this system .
Also manufacturers know how much air a given MAF meter will flow with atmospheric pressure behind it . The only variables will be atmospheric pressure and temperature and these aren't hard to allow for .
Things that do change are engine and bay temperatures especially in warm weather and with stop start running . The inlet tracts ie manifolds heat up and the slow moving air absorbs this heat more easily . Everything now has oxygen and knock sensing so the EMS can compensate for slightly more extreme conditions , computers also self learn these days attempting to stay within fairly narrow ranges for emissions reasons .
IMO the reason why some OE engines have Mass and air temp sensors is because continuous full load running heats the engine and its bay to temperatures a production car would never normally see and slightly leaner running kills things eventually . It's not hard to see why say a GTR has a basic air temp compensation sensor where GTSTs don't .
Nissan and no doubt other manufacturers have moved to better air flow meters than they used in the 80s and 90s because they are all chasing accuracy and ever tightening engine controls - and its driven by emissions and consumption legislation .
I reckon hats off to a MAF sensor where you can remove/replace the element without pulling the ducting apart , its made things easier for the aftermarket who can make a larger body and use the OE element .
A .
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
