  • 1 month later...
Found the plug here for these:
http://www.rhdjapan.com/hpi-r35-airflow-meter-harness.html
Warning... there are now copies of the R35 MAF sensor floating around on ebay etc. These are being made in China and stamped as such
You can now also purchase weld on bungs in 3" - 4" tubing for these MAFs (place called MRP Machine shop in the USA makes them). I stock a few of these units
These also fit the higher flowing Mass Air direct HPX MAFs which I'm starting to stock now to support Nistune customers. You can resize the MAF curve in the software to accomodate a MAF which potentially measures over 500rwkw by sizing the curve to what you actually require for the vehicle (for example my S14 only uses less than half the range)
More info here on using these MAFs
http://nistune.com/docs/Nistune%20MAF%20Tech%20Notes.pdf
  • 5 years later...
47 minutes ago, Bobblehead said:
What is the easiest idea for matching the connector to sr wiring please?
Would that not be to connect the correct wire from the ECU to the correct terminal on the new plug that you buy to go with the meter? The wiring diagrams are all easily findable.
  • Haha 1
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
