Hi Guys/Girls
I have a Black R33 GT-R wreck that I will be parting out now. Engine will not be sold as i will be installing it into a drift car.
So here are the parts that will be up for sale:
Front bar - $600
Front guards - $400
Bonnet - $600
Front seats - $750
R33 Gtr gearbox - $800
Diff - $400
Driveshafts - $150 each
Hubs - $400
Front and rear cradles - $150 each
Lower control arms, front - $120
Fuel tank - $100
Stock R33 Gtr suspension - $300
ABS unit - $200
Stock air box - $250
Intercooler piping - $200
Stock BOVs - $140
Brake master and booster - $100
4x R33 GTR rims with tyres - $1,000
Brembo brakes - SOLD
Front stock strut brace - $100
Rear stock strut brace - $50
Boot lid with wing - $400
Rear bar - $250
Tail lights - $120 pair
Inner guard liners with factory air guides $150
Doors - $300 pair
Excellent condition, does not include interior trims
Door trims - $200 (no window switch)
Window switch - $50 drivers side
Window switch - $50 passenger side
A pillar trims - $50 each
Full set of R33 Gtr floor mats $200 in Excellent condition
Centre console $100 Ecellent condition
Includes Gtr badge
Console stereo surround - $30
Cluser (9x,xxxkm's) - $230
Climate control unit - $40
Triple gauge cluster - $150
Steering wheel - $300
Dash pad - $100
Rear vision mirror - $20
Sun visors - $10 each
Rear seats - $300
Seat belts - $40 each
B/C pillar trims - $50 each
Complete boot interior - $150
Space saver - $100
Rear window - $200 Remove yourself
Set of wipers - $50
Wiper motors - $50
If the part your after is not listed, please feel free and ask for the part you are after, and i will check if available.
Contact - PM.
Will post some photo's when i get the chance or what ever part you need, I will send a photo to your email, or mobile phone.
https://www.sau.com.au/forums/topic/409393-wrecking-r33-gt-r/
location, and is the rear diff V-spec or non V-spec( A-LSD) If it isnt im veeeery interested in the rear diff and shafts. Please pm me if its more suitable
Location is Melbourne.
It is non vspec mate.
hey mate,
do you have the stock rear anti roll bar brackets? they just sit around the bar and bolt up to the car's cradle... posted to Sydney
Hey mate.
I should have the rear anti roll bar brackets, but I'll have a look after work to be on the safe side.
Hey mate can you please send me the pics of the bonnet and the front bar (0430971881) also what condition are the seatbelts in?
Thank you.
Will send you pics after work. Seat belts are in excellent condition.
Hey mate.
PM me your price (including postage to Sydney)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
