Hi, I've got a series 2 C34 Stagea that the wife drives, when we went to clean the car couple of days ago we noticed the carpet in the front drivers side footwell was damp and the underside of the floor mats were wet. Not wanting the carpets to go moldy I've pulled out the drivers seat pulled up the carpet and noticed that there was alot of water collected in the front and rear footwell and the white foam was soaked. I've soaked up as much water with towels as I can and am currently drying the foam and carpets out with a hair dryer.
Does anyone know a possible scorce of the water? The wife usually has the air con climate control on all the time and I originally thought it could be condensation from the rear foot a/c duct but it seems like alot of water for that
Any help or similar experience stories and solutions or fixes would be greatly appreciated cause I don't way it collecting again
https://www.sau.com.au/forums/topic/409399-water-in-foot-well-c34/
It would definitely be worth checking that the drain from the aircon condenser hasn't fallen off, or isn't kinked or blocked; this could result in all the condensate water from the aircon running down the inside of the firewall.
Water from your heater core should be green; this is the colour of the coolant you should have in the cooling system.
:wacko: I have the same problem. Pretty sure its not the heater core as the coolant level is not going down. Most of the water comes down the LH side - must find the aircond drain and maybe the drain from the sun roof but it could be something else altogether
yeah exactly, the front sunroof drain is a plastic pipe down the a pillar to the front wheel well somewhere, the rear drain down the C pillar to the rear wheel well.
mine leaks from the front sunroof drain into the passenger footwell, with all that lovely sound deadening it can stay damp for ages unless you dry it out.
but since I've never worked out where mine is blocked, I just don't park it nose downwards when it rains :)
Ok so if the sunroofs drain down the passenger side pillar why would the water be in the drivers side foot well? It seemed to of collected most near the trams tunnel near the rear a/c plastic duct thing (where the hump is, left side of the drivers side footwell)
you've got me there, no way for water to get over the transmission tunnel. maybe there are 2 drains, one on either side. mine always leaks passenger side.
also ac drain is on the passenger side.
heater core is above the trans tunnel so it could leak either side, but coolant is a very specific colour and smell, you wouldn't confuse it for water (unless you are running water in the radiator of course)
Has it been raining much in your area recently?? I had the same thing with my car a while back. It had been raining for weeks and i noticed 1 day that the carpet was damp. The water was getting in somewhere (unfortunately i didnt find it), but as soon as the rain stopped it dried out. No matter how much i ran the hose over the car, i never found where it was getting in.
I have just replaced the heater core in a C34,with one from an R33, the existing core was maked as Laurel. The core had a hole in it I think due to no green stuff in the water.
It was leaking into the drivers footwell through the ducting, with less water in the passenger footwell.
As it was the first time I have had to do this, I removed the entire dash pad, centre console, loosened the steering column and everthing to get to it, after doing it I think I would be able remove the core without taking the entire dash out.
The hassel was removing the passenger air bag to get at the fan out of the way to access the core. It is a mission even for me who takes cars to bits on a regular basis.
There three units that make up the heater setup, Ducting director, fan assembly and heater core assembly.
Took a day to get out, replace and back in.
I suppose it's possible just to get a radiator place to pressure test the heater core and see if that's the cause of the leak
Well yes you'd just be pressure testing the whole system with the heater full on and looking for the leaks! I got a heater core for my last Stagea (I'm on my third C34!) brand new from the local radiator shop - once they see it they can match it up - they are common with a number of other cars.
Checked the carpet again today and the water is back :(, I might have to try to bypass the heater core dry it out and see if it comes back again. Is there a guide to changing a heater core or do you just keep taking stuff out until you can get to it, the cars got a xanavi climate control unit, will it be any problems if I bypass the core?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
