R33 1993 Silver Manual Shell
This is still registered in vic, so can be registered. Not written off or anything, just stripping a track car.
This is what it comes with:
Engine Bay
No head (have a spare stock head with exhaust studs snapped off inside for free)
Have stock turbo, manifold, intake manifold etc if you like
Block, in good condition, still installed
engine loom
All pumps
Accessories
No air con or lines
Walbro intank pump
No exhaust
Suspension/Driveline
No Gearbox
HSD HR coilovers
Cusco camber arms front and rear
Adjustable toe rods
Adjustable castor arms
Adjustable traction rods
Tie rod ends
Upgraded bushes
Hicas delete bar
Whiteline swaybars
Kaaz 1.5 way diff
Brakes
Dba4000 rotors
bendix ultimate pads
braided brake lines
Wheels
None atm, either will have to find stockies or supply your own
Exterior
Nismo front bar with canards
Nismo sideskirts(not in very good nick)
F1 carbon mirrors
tinted windows
bonnet pins in stock bonnet
stealth wing(modified to fit gt wing)
Interior
stripped interior including sound deadening
everything under the dash stripped(i.e. heater box etc)
stock front seats
still has driver/passenger seat belts, rear view mirror.
Looking for $2000
Have gearbox and other parts advertised separately
Located in sydney
Any q's just ask, probably forget a few things
Pic here
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=378209
there are some more pics in my build thread.
Just to note this still has a full loom, hasn't been played with.
Comes with fuel system aswell which includes:
Walbro intank
1.5lt surge tank
bosch 044 external -
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
