I don't get to drive my toy much but noticed soon after buying it that it was VERY fuel inefficient. When I say very, I mean absolutely appauling. People say yeh it's because you drive a GTR with aftermarket turbos, well yes, average fuel consumption is somewhat expected, but I am only getting 180-190 km per tank!!! It's actually laughable (and cryable for my wallet!). What mileage is everyone else getting? Please state your engine, ECU, turbos, and injectors as follows:
Engine: RB26DETT
ECU: Apexi Power FC D jetro
Turbos: Garrett -5s
Injectors: Sard 800 cc
Cheers.
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/
RB26DETT
PFC, nismo AFM's
-9's
555cc
Around town, 400-420km
Hwy 100-110km, 550km
I use 5th at 60-80km and 6th over 80km.
Some people I've noticed use the wrong gear for the speeds they do, ie 3rd gear at 60km..... you think they just want to be ready to boost off or something.
All you do is wear engine quicker and use a gut load more fuel.
There is using the wrong gear like 5th at 40km/h up a hill, but come on!!!
O2 sensors seem to be a common culprit, and also lazy tuners that don't spend some time tweaking the light load/cruise map, and you end up with poor fuel economy.
Shouldn't matter what size injectors that are used too. I think ecomony matters as it = more fun km per tank :D
And Michael, geez that is like E85 fuel economy!!!! That ain't right!!
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6535961
RB26DETT
PFC, nismo AFM's
-9's
555cc
Yeh I know!! I spoke to Chris at Racepace and he tells me the injectors I've got are one culprit as is the PFC d'jetro which inherently has to be run richer. I get a buttload of unburnt fuel literally spitting out of the exhaust at idle :/ Apparently the guy who tuned it in Tassy wasn't familiar with the power FC (which is clearly evident) or confident in tuning it, but I didn't think it was possible to have THAT bad of a fuel economy.
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6536038
See if its still running 02 feedback if you have a hand controller for your Power FC. If so then it could be your 02 sensor(s). I'm not sure how they work in the GTR's (There's 2 of them in a GTR right?) so if ones stuffed and ones good I dont know what this would do to the cruise AFR's
If 02 feedback is off, Then its possible that your cruise AFR's werent tuned or werent tuned properly. I have mine tuned rather then running 02 feedback because I can run it slightly leaner at cruise AFR's. The Power FC, I think aims around 14.5:1
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6536317
I've had PFC D Jetro on this one and the previous > both gave me 400+Km/tank ie more accurately 14.5l/100Km and a bit more with squirts (but not peak hour traffic)
State of tune was tops on both cars.
Both run 600cc Sard
Both run -7 or N1
Methinks your consumption is excessive, so 02???
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6536440
Engine: RB26DETT
Turbos: Garrett -5s
Cheers.
as i ask in every fuel economy thread like this, how many Litres are you calling "a tank"? without this we can't tell whether you just have bad economy, extremely shit economy, or a dodgy fuel gauge
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6537539
A full 34 GTR
A full 34 GTR tank which i think is 50L??? I think you could definitely regard it as extremely shit economy - Its about 23L/100 km :/
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6541301
Just to rub it in a bit more I got 404kms today on 48L so 11.9/100 and that included an hour on the dyno which spent quarter of a tank on the gauge.
Was going to get wideband to tune for economy but don't think I will bother.
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6541319
A full 34 GTR
It's a 65 litre tank, but I have managed to fit in 55 litres when the fuel light was on for a while..... :whistling:
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6541461
If the economy is that bad, you may as well switch to the E-flex and retune with a better tuner...
I was getting 450km average on 98
now getting 300-350km out of E-Flex
when the light comes on i have about 10-15Litres still in there, have measured 10Litres when its below the empty line..
Edited by SliverS2
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6541612
Do you have a copy of your d-jetro map that you could email me? ian @ isit.net.au
I use a d-jetro and see around 180-200km/tank if I drive like a nutter. Best on the open road is close on 8-8.2lt/100km now.
Have you adjusted your cam timing with gears? If so, what are your new settings.
What is your cruise speed and gear generally...?
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6542187
You guys have me starting to worry about fuel economy because at best I get around 15l / 100km and it is not difficult for it to drop to around 21 or 22 when you really start to push it.
I still have the original o2 sensors in the car so it looks like they probably need replacing.
https://www.sau.com.au/forums/topic/409433-fuel-efficiency/#findComment-6545118
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
