Hi all,
Just wondering if people generally write the actual amount on the transfer papers when they buy their R35s. From the department of transfer website, the stamp duty for a 110k is over 7k..which is rediculous considering how much we get taxed for everything else as well. I know only it's part of the cost of buying such an expensive car but how can you reduce this cost. Do you just write a lower price on the transfer papers? if so, and the seller agrees to write it, how low should i put it on the transfer paper. Has anyone ever be caught out doing this?
Cheers
https://www.sau.com.au/forums/topic/409455-stamp-duty/
I think the rule may be based on purchase price OR market value, whichever is higher.
http://www.rta.nsw.gov.au/registration/feesconcessions/stampduty.html
They probably have a redbook style database of values.
I wouldn't bother trying to lower the value too much beyond the approx. current market value, whatever that may be.
https://www.sau.com.au/forums/topic/409455-stamp-duty/#findComment-6536471
Go market value, never actual sale price.
I sold a Mazda MPS a few years back for $31k, wrote down $22k and the new owner got a way with it too easy. Probably helped that QLD transport had no idea what an MPS was at the time - just another Mazda 3 lol
https://www.sau.com.au/forums/topic/409455-stamp-duty/#findComment-6536479
I don't understand why there is stamp duty on cars after the first sale. They get a MASSIVE cut when its new, then proceed to take more off the top over the life of the vehicle - essentially double dipping the honey pot.
It's therefore in our best interest to record the lowest value possible, because there is no way it would cost $7k to do the change over paperwork on a 2nd hand GT-R.. What an effing rort..
https://www.sau.com.au/forums/topic/409455-stamp-duty/#findComment-6536493
I wish there is some way around this, I guess I can only ask the seller for a favour when writing the price. How low do you think i can write the market value without it being questioned? also, for a 110k car we have to pay 7.1k in stamp duty in WA where as in NSW you guys pay 4.6k..why is there such a big difference
http://www.transport.wa.gov.au/licensing/1382.asp
Edited by vspecR
https://www.sau.com.au/forums/topic/409455-stamp-duty/#findComment-6536498
Another interesting question is
If a car is sold for 150k value , written down as 90k to avoid duty's
insure the car for 160k agreed value ,
Car gets in accident written off would insurance void it ?
In short NO.
Agreed value is as it says agreed value.
However, the insurance company will try other ways to get out of paying it.
https://www.sau.com.au/forums/topic/409455-stamp-duty/#findComment-6536688
At no time will the insurance co ask for your change of ownership docs. You pay for what ever agreed value you want when you insure your toys, so write down the lowest value for the GTR as you can - $90k is very reasonable for the change of ownership forms IMO.
Edited by Wardski
https://www.sau.com.au/forums/topic/409455-stamp-duty/#findComment-6537241
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
