Hey guys
Have found A new project and wont be needing these brakes or wheels anymore as they no longer suit the application.
The front calipers and rotors are brand new and havent seen one day of work yet..
The rear calipers and rotors have been used for one or two track days, cant remember.. Bought them along time ago.. Still pretty much as new..
The fronts are 6 pot 383mm x 36mm and the rears 4 pot 343mm x 34mm all rotors are two piece..
I bought these from another member on here jagr33 quite some time ago and have never used them since..
They will suit any skyline from r32 to r34 or silvia from s13 to s15. Just need to redrill your front uprights for 14mm bolts, the rears im assuming on all above models are for 10mm bolts
I am chasing 7.5k + post
Ame TM02 wheels as new measuring 18x10 at +15 offset, with achilles 123s semi slicks 1000kms of highway driving on them measuring 265x35x18.. I pretty much put the tyres on and drove from brisbane to mackay then parked it up..
The wheels are perfect with only the minor mark or two from the socket i used to get the wheel nuts on and off.
And yes these wheels do fit the above brake setup underneath them quite easily unlike most 18" wheels
Chasing 2400 for them + post
Anyways please send me a msg or give me a call on 0433549640 or if you dont mind waiting for a reply send me a pm.
All parts in mackay qld, pictures up soon
Cheers spencer
Edited by spenda
They should fit, all you should have to do to drill out the holes where the caliper bracket bolts to the hub to suit your 14mm bolts as he mentioned in first post.
but the caliper brackets will need to be drilled out to 14mm or the bolts wont fit in.
Think about it, why would you need to drill out your hubs / uprights to 14mm if you have r32/r33 or an s (or Z) chassis car?
Because the brackets these brakes come with are to suit 14mm bolts.
Sorry man, the way i read it was that you would have to drill out the uprights (which i thought were the dog bones / brackets), not the hub to suit the 14mm bolts.
If not, my bad.
So yes they will fit.
Cheers.. These ames are the gunmetal grey ones..
Sorry guys both items are no longer for sale as i have found the money to fund my new project elsewhere..
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
