Hey guys,
I recently did a turbo upgrade and everything was fine for a couple of weeks (just a bit rich). Driving home from spectating Powercruise i was getting on the highway and when i pushed the throttle in, it gave a small pop and then started to miss under full throttle.
The car has a Stinger EMS ecu, GTR injectors, GTR fuel pump, Yellow Jacket Coil packs.
So far i have checked/cleaned the plugs (covered in carbon), Taped the coil packs, checked for vaccuum leaks, checked the fuel maps, used a multimeter on the ignitor (wouldnt read anything on ohms)
I have searched this forum and many others for possible causes and solutions and so far have come up with nothing.
Any help would be appreciated, even if you have a spare ignitor/AFM around Brisbane that i can test to rule some things out would be awesome.
Edited by bunnyfart
Massive thanks to SIFTY32 for letting me test his ignitor and coil packs. Nothing changed when i put his on so that rules them out. I ran a data log on my ECU and when i had my foot to the floor with no load the TPS was jumping from 100 (full open) to around 70 - 80 (not full open). My thought process is that the TPS is telling the ECU that my foot isnt to the floor when it actually is.
Is there a decent way to test the TPS with a multimeter?
Do u have an aftermarket throttle body?
I have had 2 cars lately that have had freeplay between the tps and throttle shaft.
Use a multimeter between the Signal wire and the earth wire.
Should read around .5v closed and 4.5v open completely
standard throttle body. Used the multimeter on the 2 wire and got 1.9 ohms but when i started to move the throttle butterfly it made the multimeter turn off until it was returned to closed.
I changed it to V and got 1.0 on closed and again it turned off when it was opened
Edited by bunnyfart
Ok, it seems my missfire has been solved by disconnecting my aftermarket water temp gauge from the 2 wire sensor.
Its running really well now with better fuel consumption and able to rev really easily.
Can anyone explain to me why the water temp sensor would cause such a massive issue with my car?
I never understand people that wire things in without researching.
Yes thet makes perfect sense as the coolant temp sensor is very sensitive to voltage. It even runs its own seperate sensor ground with only a few sensors like TPS and CAS.
Glad u found the issue
