Hello everyone.
Picked up a stock standard example of an S15 after looking for several months. It is 100% straight, all original panels and all original paint. There are lots of accident damaged S15's out there unfortunately so it usually takes a while to find a nice one (if you know what you're looking for).
My main focus is response and handling. The tuning concept for the car is "Bakemono". The build will predominately utilise Japanese parts for authenticity.
The car is being built for a purpose, that is, it will be a sleeper. There will be little focus placed on aesthetics. The car will be left looking relatively stock on the outside so I don't draw attention (attention can be good, but it can also be bad and come from the wrong people).
I've got a stack of parts waiting to be installed, but here is the most recent arrival.
I have some more stuff in transit from Japan at the moment and some other current inventories.
Will update the thread every so often once things begin progressing.
https://www.sau.com.au/forums/topic/409507-bakemono-nissan-s15-build-thread/
Here is the first package I received from Japan and the quality of the items is phenomenal.
Especially impressed with the HKS Hipermax III Coilovers, definately worth the money. Unfortunately, I believe they have been discontinued now.
Front set.
Rear set.
HKS Tool Kit (came with the coilovers). I like how they threw in some zipties haha.
Rear upper camber arms are the pillow type. For the Rear Toe Adjustor Rods and Tension Rods, I elected to go with the rubber bush type as this car will be predominately street-driven. The rubber bush ends will be quieter and won't wear out as fast, and they have slight play in them due to the flex of the rubber (which is actually ideal for the street).
Tension Rods (aka Front Castor Rods).
Rear Upper Camber Arms
Another package arrived from Japan a few days ago
Top Secret Shift Knob
and...
HKS Catback System.
Once again, the quality of all the HKS stuff I have received so far has been exceptional. Have been very impressed with the workmanship.
What dump and cat are you going to run Bentji?
I was going to run the HKS GT Extension Kit but Streeter told me it had been discontinued. Would of been ideal as I would have had way more ground clearance. Plus, the design was very good for response.
Instead, I bought a used CES Racing Front/Dump Pipe off a wrecked S15 (had a slight crack near one of the welds, but mechanic said he would weld it and it will be fine).
The mechanic has a contact who makes the hi-flow cats and he recommended I get a 200 cell one.
This arrived in the mail not long ago....=D
Also, 22 days until I can get my full licence.
Update on the car:
Car has been sitting since the trackday at Wakefield on July 26th, so safe to say all the fuel would be stale by now.
Checked tyre pressures and they're down to 20psi. Brakes still haven't been organised and are metal on metal, so need to get that organised.
Going to DIY the coilovers/alignment arms with a member from JDMST!! This will probably happen sometime in November once I'm finished uni for the year.
Got a CES Front/Dump Pipe lined up and need to get a Hi-Flow Cat
Thought this sticker was lulzy, so I played up the stereotype of S15's being used as drift cars.and I installed it.
Tomei N2 Oil Pan
I like how Tomei has included some English instructions (for people like myself who can't read Japanese)....and two stickers :D
Hey Benji, Although your car isn't heavily modified so it shouldn't be too much drama try to keep things stealth and no sticker etc.... The cops around here are pretty hard on imports and you don't want any un-necessary attention! Also, the DIY thing will apply to the exhaust, brakes and suspension as it is all pretty straight forward. Like i said, try GSL if you want good brakes at a cheap price, if you are sticking to all name brands i have ENDLESS pads and rotors in my car and they have been nothing but awesome!
Yeah didn't really think of that....probably not a good idea having that sticker on there (e.g. if a HWP has a look inside the car).
Also, assuming the hi flow cat will be fully flanged up, itd be as simple as just putting bolts in wouldn't it? Or do you have to use sealant as well?
Yeah just been researching brake rotors etc and still weighing up the pros and cons. How are the endless pads and rotors for the price?
Yeah the thing is literally bolt up, really easy to do! Just use new gaskets! You could seal them up but i wouldn't as when it comes time for a clutch change or if you want the exhaust off for some reason it just makes a hassle, just bolt it up nice and tight and it will be fine, they are a direct swap in most cases.
The DBA. RDA etc will all do the job, i have been running stock rear rotors for the entire set of endless pads and the held up fine, the front rotors are endless though..... I would suggest the DBA 4000 series rotor with a decent pad, however i will be trialling the QFM pads as they are cheap and get a solid review!
nice one benji!
quick question, why did you get an S15 and not another S13, and build it up?
Yeah, I got an S15 because I couldn't find another S13 in good condition....finding an S13 that hasn't been bent from an accident is like finding a needle in a haystack.
S13 is definately a more fun, enjoyable car though, providing the condition is good (like my old one). Looks cooler + has more character than a S15 i.m.o
In all honesty, should of looked to import one from Japan, but couldnt be bothered going through the hassle.
Wow! There is some awesome stuff going into this car.
What diff are you running at the moment?
Thanks =).
Just running the stock Helical LSD at the moment.
Might go for a Nismo GT 1.5 way later on down the track, but not necessary yet.
Nice and look forward to seeing your power mods. Go for HKS GT-RS low mount turbo, it is a match in heaven for stock SR20. I used that setup in my last s15 and absolutely loved it and looks nearly original under the bonnet! Here is a photo of it :
  • Haha 1
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
