  On 20/08/2019 at 9:15 PM, ActionDan said:
Stock bottom?! Wasn't it done with the $$$$$ head?
Assumed stock box would be removed as nobody would expect it to last behind anything decent, especially a 6spd.
Expand
"Apparently" the same type of Aisin AZ6 gear box that's in my 86
Rated to 250nm
I learn something new every day!!!
Stock bottom will go bang with 400kW+
Box will die easily with 250kW with a few laps at Wakefield.
S15 bottom will do 320 to 340kW with torque being limited either via timing or boost control strategies.
Should do a 5 speed swap using a R33/34 RB25 turbo box.
None of my cars will be seeing the track, I'd rather just enjoy the cars every now & then.
That's enough for me, I'm not a millionaire to be able to afford track days or risk losing everything.
I'll have to assess the gearbox stage carefully.  My money can go so much further on travel around South America, so Id rather ignore a gearbox solution as long as possible.
What do you mean no track? ;)
  On 01/06/2019 at 1:43 AM, BakemonoRicer said:
Haha I’ll float the car to Adelaide and line you up on the circuit mate. We can put $5000 on it to make it worthwhile. You’ll probably get crossed up trying to match my late braking & end up in a tyre barrier, so when I win you shall refer to me as “The Don” and comment my thread admitting the car is a museum piece
Expand
  • Like 2
  • Haha 3
  • 4 months later...
Overr the christmas holidays I decided to get stuck in and work on the car. Started off with reinstalling the bonnet & mocking up the front bar. Installed a big spec Cusco Swaybar setup. I was really pedantic on making sure its completely equal each side, so measured off the chassis rails until it was exact (a step most people miss for the front which can be done wrong very easily). Swaybar was installed with the wheels loaded on the ground, and all new OEM endlinks & endlink bushes.
Next step was to sort out the interior, so I worked on running all the sensors for the DEFI gauge & the positive battery cable to the boot. Aligned everything real nice & it was back to looking like it'd never been taken out.
The engine bay is really starting to come together, the next step is to get the car towed to TRP for another don mega fuel system, then get it wired & Emtron'ed...I'd like to think I'm only a few months away from having the badger up & running.....
  • Like 1
Good work.
What shocks are in it? I found that my car had a lot more grip opn stock sway bars, with a whiteline in the front and GT-R in the rear it was full flat cap drift spec and just wanted to slide everywhere and would not transition weight smoothly.
Could be because it has those cheapo BC golds in it, firm spring etc.
  • 1 month later...
Bought another Emtron KV8 last weekend LOL. So now it's simply Fuel System, Wiring & Tune to go.
Dan, the coilovers are HKS Hipermax III 6kg F/4kg R. The Ohlins in the GTR kill them in every department, but that's comparing apples with oranges really.
MLR, no the swaybars aren't adjustable.
I had those in my first GT-R, the Hypermax, I quite liked them.
Keep some stock sway bars on hand for tuning the setup, you might find it's too stiff to put power down cleanly.
Good to see some progress again. Nice work.
Expand
Why dude? You have a gearbox that is lucky to survive with the stock turbo bolted onto it. f**k the 6 speed in your car makes a WRX gearbox  look strong!
You have a stock motor that will be able to be turned up to what 270kw max? Throw a single 525 in the tank and put your money to better use dude. You won't even need E85 for that kinda power with the 7670.
My car was at the power/torque limit of the motor at E15 dude so theres no way you are gunna be near those numbers lol. Dexter said you are out of motor that's it.
You do know Scott WILL NOT push the limit of a stock motor. Take it from me i know! He will give you whatever he feels is safe and that's it.
I really struggle to see your logic in these $4-5k Don Mega fuel setups for a million kw when you literally need a $250 single in tank pump to start enjoying this car?
Put your money towards a gearbox, a diff and at least some Evo calipers to help this thing put the power down and stop...
I can assure you it won't make it off the dyno with that 6 speed mate & you know it. The fuel system money is literally your gearbox & diff almost paid for.. Then theres the other bills you dont see like the tow truck back to Rigoli & the dyno time you will pay for with an incomplete tune.
THEN pay for another tow back and the tune to be finished. Give the tuner a car setup properly so it goes on the dyno and gets driven home not 1 that that leaves on a tow truck for repairs cos it's broken!
It's a beautiful car with all the cream dude why hold it back with shitty stock parts for junk that you simply DO NOT NEED ?‍♂️
Edited by Mick_o
  • Like 5
^ Completely agree.
My fuel system won't be anywhere near the Don Mega Spec stuff and my SR will make a fair chunk more power and be used in harsher conditions - and happily.
No way would I attempt 300kW on a 6spd box either. A 5spd might barely hang on with really gentle shifts and soft torque ramping but realistically you need to budget for a Z32/RB25 or better yet CD009 (if you want manual).
Edited by ActionDan
Much agree with Mick_o but i like the Don mega spirit as long as im not paying.
So to complement the Don mega fuel system, how about a Don mega gearbox (samsonas, hollinger, ppg, albins, tti, etc. choose your flavour). Run your 300rwkw+ without gearbox explosion at any time hanging over your head. That would be Don mega, not to mention f**ken quick.
Finish off with number plate
THE DON
DON MEG
DONMEGA
DONE
It needs the fuel system that’s what makes the power it has to be delivered efficiently to quench the thirst of the big port head! Already stripped the stock pea shooter hard lines out its time for the Teflon don upspec. Fuel pumps, flex sensor and custom alloy surge and hat all done.
Gearbox is the only weak link, if I blow the 6 speed That’ll get turfed for an AL’s RACEGLIDE!!!!!!!!
  • Confused 1
lol, no Benny. It does not need that fuel system to suppotrt 300rwkw - regardless of what's in the head.
We've been down this road before though, you get an idea in your head and it's very hard to convince you so just go ahead and waste the money, no skin of our noses :)
Expand
1× 525 Walbro supports my tiny 325awkw on E85 dude. So it will support your 260rwkw on 98 just fine.
If I was you I would call Al and give him a deposit on that glide now so that way it's ready to be swapped out on the dyno. Hopefully the box lives long enough for at least 1 power run for that dyno sheet ?
  • Like 1
You guys just don't get it.
Those pumps only work for you because you don't have a Don mega flow head from Naprec.
Sure, the combo is going to be dialed down to help the bottom end live, but big heads need big fuel. Even if 80% of it is being returned to the tank.
The higher flowing fuel in the rail just makes everything smoother and better.
Duh.
  • Like 1
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
