This head needs to know there is fuel nearby  whooshing through the fuel rail on its way back to the  tank, so it can be comforted by knowing money has been spent. ??
  • Like 1
  • Haha 1
On 21/02/2020 at 6:36 AM, admS15 said:
1 x DW340 supports 312 rwkw on e85 for me through stock hard lines, stock rail, stock fpr.
Anyway, Samsonas. Do it bro.
Yes to Samsonas, and also mechanical fuel pump.
Running electric fuel pumps isn't Don Mega in 2020 anymore.
The game has changed, 2020 is about 1000+ up, Samsomas sequentials, mechanical fuel pumps and MoTec M1
  • Haha 1
  • 2 months later...
Have been working two jobs to try & get this puppy on the road.
It's looking like I'll get it towed to TRP towards the end of this month.
As the focus is a nice streeter / track day machine I do think once tuned it'll be boost limited to conserve gearbox/bottom end.
  • Like 3
Man, I don't think anyone will be getting a samsonas haha.....we all need to keep our jobs first!!
Massive layoffs happening in construction industry atm!! I guess when the government cant make their mind up to starting big building projects thats what happens
  • 1 month later...
Build has entered raging bull mode. TRP have taken charge of the build now and started on the don mega fuel system, within a week it's just all out NASA spec really and not even necessary yet however I'd already forked out the coin (years ago) for plenty of Earls Ultrapro teflon, custom surge tank, custom fuel hat, etc so I went for it. Next up will be to finish the catch can filter, tidy up all the lines, fit oil pressure / 2 x map sensors, then its off to Insight for wiring & flex tune.
  • Like 4
1 hour ago, Dose Pipe Sutututu said:
If it is "Don Mega" or "NASA" then you shouldn't be using a welded up surge tank :)
don't be so sure:
https://www.nasa.gov/centers/wstf/supporting_capabilities/machining_and_fabrication/welding.html
However, I am ready for the challenge of who will break their gearbox first at Wakefield.
this you can be 100% sure about :P
10 hours ago, Dose Pipe Sutututu said:
Bosch stepped their game up! Nice!
Dose, AI didn't make the cut, their surge tanks are too small, look at the volume those pumps take up, damn near the whole canister. I had no choice but to go big spec with aircraft grade alloy and 10L volume.
Gonna be needed to keep the fuel cool when I'm full tilt at wakefield coming in hot through the kink, should help with a bit of weight over the rears to keep me planted.
Micko, no Elixir in main tank, I would of needed a billet cradle for that puppy so for once I didn't spend the dollars. Leaving the Nismo lift pump in there.
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
