Read: "I don't know"
Meh, I'm just here for the biscuits.
I believe the stock gearbox is good till 250nm, I think it is the same Aisin AZ6 thats in the BRZ.
So.....needs more T56
59 minutes ago, ActionDan said:
Fair go.
You know how rarely a car goes on and off the dyno as scheduled lol
Normal cars yes they have issues, this is not normal. NASA spec aeronautical aluminium etc
  • Haha 2
My thoughts have changed.
Car made so much power and was so impressive the shop wouldn't let it off the dyno. They can't believe it is possible and are getting dyno checked over for faults.it it is made harder because everyone is deaf because of the extra noise caused by special 2into 1 exhaust merge and no squish pads in the head
that or they are still trying to figure out to strap it down
  • Haha 1
Yes it definitely is a special merge for the ultimate sound and I will sue if anyone tries to copy me
It's a mission to hold the thing back, it is making power in a way that JUST hasn't been seen before.
I paid a premium to NAPREC for their special ingredients, it's their only Australian SR20 so they just went full-tilt. It's a stage 5 head.
  • Haha 1
Did you get a stage 5 result yet or what Benny???
6 hours ago, Mick_o said:
I have a feeling it may only be a stage 1.5 result ?
Stage 4th gear results maybe?
With the head that decimates all, it may have made don torque low in the rpm range and made 4th gear go bye bye.
Bokey, tell them the price son....
On 26/06/2020 at 2:18 PM, mlr said:
45 minutes ago, Ben C34 said:
He is actually working for NASA now. They couldnt  believe how well the merge worked and are going to use it on all their rockets.
It's all about where the merge separates
  • Like 1
  • Haha 5
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
