This head needs to know there is fuel nearby  whooshing through the fuel rail on its way back to the  tank, so it can be comforted by knowing money has been spent. ??
  • Like 1
  • Haha 1
On 21/02/2020 at 6:36 AM, admS15 said:
1 x DW340 supports 312 rwkw on e85 for me through stock hard lines, stock rail, stock fpr.
Anyway, Samsonas. Do it bro.
Yes to Samsonas, and also mechanical fuel pump.
Running electric fuel pumps isn't Don Mega in 2020 anymore.
The game has changed, 2020 is about 1000+ up, Samsomas sequentials, mechanical fuel pumps and MoTec M1
  • Haha 1
  • 2 months later...
Have been working two jobs to try & get this puppy on the road.
It's looking like I'll get it towed to TRP towards the end of this month.
As the focus is a nice streeter / track day machine I do think once tuned it'll be boost limited to conserve gearbox/bottom end.
  • Like 3
Man, I don't think anyone will be getting a samsonas haha.....we all need to keep our jobs first!!
Massive layoffs happening in construction industry atm!! I guess when the government cant make their mind up to starting big building projects thats what happens
  • 1 month later...
Build has entered raging bull mode. TRP have taken charge of the build now and started on the don mega fuel system, within a week it's just all out NASA spec really and not even necessary yet however I'd already forked out the coin (years ago) for plenty of Earls Ultrapro teflon, custom surge tank, custom fuel hat, etc so I went for it. Next up will be to finish the catch can filter, tidy up all the lines, fit oil pressure / 2 x map sensors, then its off to Insight for wiring & flex tune.
  • Like 4
1 hour ago, Dose Pipe Sutututu said:
If it is "Don Mega" or "NASA" then you shouldn't be using a welded up surge tank :)
don't be so sure:
https://www.nasa.gov/centers/wstf/supporting_capabilities/machining_and_fabrication/welding.html
However, I am ready for the challenge of who will break their gearbox first at Wakefield.
this you can be 100% sure about :P
10 hours ago, Dose Pipe Sutututu said:
Bosch stepped their game up! Nice!
Dose, AI didn't make the cut, their surge tanks are too small, look at the volume those pumps take up, damn near the whole canister. I had no choice but to go big spec with aircraft grade alloy and 10L volume.
Gonna be needed to keep the fuel cool when I'm full tilt at wakefield coming in hot through the kink, should help with a bit of weight over the rears to keep me planted.
Micko, no Elixir in main tank, I would of needed a billet cradle for that puppy so for once I didn't spend the dollars. Leaving the Nismo lift pump in there.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
