Read: "I don't know"
Meh, I'm just here for the biscuits.
I believe the stock gearbox is good till 250nm, I think it is the same Aisin AZ6 thats in the BRZ.
So.....needs more T56
59 minutes ago, ActionDan said:
Fair go.
You know how rarely a car goes on and off the dyno as scheduled lol
Normal cars yes they have issues, this is not normal. NASA spec aeronautical aluminium etc
  • Haha 2
My thoughts have changed.
Car made so much power and was so impressive the shop wouldn't let it off the dyno. They can't believe it is possible and are getting dyno checked over for faults.it it is made harder because everyone is deaf because of the extra noise caused by special 2into 1 exhaust merge and no squish pads in the head
that or they are still trying to figure out to strap it down
  • Haha 1
Yes it definitely is a special merge for the ultimate sound and I will sue if anyone tries to copy me
It's a mission to hold the thing back, it is making power in a way that JUST hasn't been seen before.
I paid a premium to NAPREC for their special ingredients, it's their only Australian SR20 so they just went full-tilt. It's a stage 5 head.
  • Haha 1
Did you get a stage 5 result yet or what Benny???
6 hours ago, Mick_o said:
I have a feeling it may only be a stage 1.5 result ?
Stage 4th gear results maybe?
With the head that decimates all, it may have made don torque low in the rpm range and made 4th gear go bye bye.
Bokey, tell them the price son....
On 26/06/2020 at 2:18 PM, mlr said:
45 minutes ago, Ben C34 said:
He is actually working for NASA now. They couldnt  believe how well the merge worked and are going to use it on all their rockets.
It's all about where the merge separates
  • Like 1
  • Haha 5
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
