I've been reading through a bunch of threads with similar issues yet nothing that directly relates so far.
If have a BNR32 GT-R and it's been a long cold winter here in Melbourne and the car felt like it was running fine and smooth the whole time. As there's been few warm days recently its been causing the car the run with rough idles and almost stalling at times. It will only happen if its on a warm day of more than 20 degrees.
I've also noticed that the engine check light will flash at times and then be ok again but other than that car will boost ok and give off consistent power.
So far I've read that it could be one of the vacuum lines in the plenum or the timing itself. My guess is that it could be the AFM's or sparkplugs. I am running stock AFM's with an ARC Airbox.
I also took it to be Dyno tested to see if the issue could be replicated but they found nothing aside from it running slightly hotter than usual after load. I am running an aftermarket radiator as well. However it was fairly cold day so it may have been easily spotted.
Was wondering if anyone else has had experiences with this and any suggestions would be appreciated!
Anytime the engine light flashes, the ECU will store that error code until you either clear it via CONSULT or disconnect the battery. Either read the error flashes from the ECU, or get yourself a CONSULT cable or one of these: http://ecutalk.com/consultlcd.aspx and grab that error code.
When were the spark plugs last changed, and what type are they (copper, platinum, iridium etc).
Can you hear any hissing (vacuum) in the enginebay while idling?
If you spray something with alcohol (wd40, brake cleaner, aerostart etc) around the intake manifold, ITB's, vacuum hoses does the RPM (engine changing note) temporarily rise?
Things that go wrong when hot but work fine cold, generally don't rule out the coilpack ignitor or the crank angle sensor. Until you get that error code, it's all guesswork and you might even be on the wrong track.
Thanks for the suggestions there. I'll go down the CONSULT route for now and see what its telling me first.
Sparkplugs I'm running are just NGK Platinums but I don't remember the gapping of it. But they are almost 2 years old now so may need to pull them and check. I changed the coilpacks a few years ago to Splitfires so I somehow doubt that would be it. :-/
Can't hear any hissing or vacuum leaks so far but will check further there but I haven't tried the WD40 with the intake manifold yet but if RPM rises for a bit is that a good sign?
thats the sort of thing that was happening when i had a intake manifold leak, was fine til it was at operating temp, got worse every day
the leak makes it run lean and thats what makes it rough and stall, but the opposite happened on full throttle, id get some big black clouds out the back, fill up half the street ..also seeing boost but not feeling the power for a few seconds cause it was blowing out the manifold... any of that happening?
Edited by SliverS2
  • 3 weeks later...
Manifold leak I'm still investigating as it seems to run ok 90% of the time.
Since its been getting warmer recently I've noticed it happening more often and I can sort of replicate it if I deliberately try to stall it where it will take over and try to keep the revs up. It will then start 'hunting' for up to 10-15 minutes afterwards.
Cruising along at constant speed it will feel erratic during that time.
I'm starting to count on the AFM's needing replacement in this case.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
