Sau Vic Show And Shine Oct 21St 2012!
that thing was a machine lol.
I used to randomly see it do a quick lap on south gipsland highway every now and then, and then go into hiding for a little while..
lol no rego.
  • Replies 119
Yep it was Bens old 3ltr, not the custom 2.9 that was built later on
The shell went to Steve (another Vic member, who purchased Leewahs old car). Arrows going everywhere :D
Another shot of Jason-san's bay before the car was stripped.
Pity it never saw the purpose it was built for :(
ha ha na my cars different to jasons still 26 built in the mist of building a 27, mines got more aero than his! i do drive down south gippsland hwy a bit to goto work!
check out more on my fb page facebook/rpowermotorsports.
If anyone needs a Detail on Saturday or before just shoot me a message at the moment I still have some free spots.
Matt
Me Mav!!!!
Call me tomz!
can i pay my renewal on the day?
I'll be doing the same, so i'll get there a bit earlier.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
