hey guys thought i may as well put a thread up since i look around this fourm reguarly.
So after owning a na ca s13, ae86 20v with itbs, ke70, ae92, 2010 ve ute, excel and now ive come to hopefully my last car for a good few years!
started life a as 91 nissan silvia s13
sr20de
manual
fully f**ked coilovers
'' '' rear lcas
" " clutch
18's... 2nv
ect ect
picked it up for 5g with 12months rego,
Good points were
Factory 2 tone
fairly tidy interior
rego
and a place to start!
Anyway, after i bought the car the clutch was 90% dead, box crunched slightly, motor missed and was oily as f**k and it was just shithouse to drive, this needed to be changed asap.
Figured if i was going to go to the trouble of taking the box out, buying new clutch, fixing motor ect i may as well do something different and fun haha
So this is were we are at.
Pulled sr and box out, along with whole front suspension, brakes, rear driveline, rear brakes, rear suspension, dash/interior
bought 25det box, tailshaft, slave, 33 crossmember, 33 brackets/mounts, full 5 stud, s15 sr20det brakes, s15 stockies, s15 full dash interior
Decided to grab the gktech catalougue and order some stuff!
which now inc more haha
Bought new rack, rack mount bushes, oem tie rods, and fitted it up to the 33 crossmember
Still have to bend some of the lines..
Got a mate to make up some spacers to sit in the s15 knuckles to reduce the bolt size from 14mm to my new s13 coilover 12mm holes,
Bought some rimssss
And finally something to much around with :D
Motor is half payed off just have to get some more stuff before i can pick it up.
If you didnt read the title is a rb25de neo
Ordered new cushion button clutch
waiting on my diff to come back, mate was welding the 4:11 up.
then ill wack that in, all the rear arms, and rear 5 stud thats ready to go.
Mate is dropping around his 32 gtr rear sway bar and ive got new link bushes to go with that.
also his whiteline adj front swaybar made for rb conversions.
Once i get engine mounts sorted and bend the powersteering lines ill put the front end up.
Heaps of little fiddly bits like lhf caster rod bracket mount, were it bolts to chassis has no thread to be screwed up lol, so now have to make my own and other shit like that.
ill put some more pics up and a list of whats to do
Pretty half ass build thread but i cbf going into every detail lol.
Can check here for finer details.
but will try update here the best i can.
http://www.nissansilvia.com/forums/index.php?showtopic=519948
Cheers matt
https://www.sau.com.au/forums/topic/409589-rb25de-neo-s13/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
