hey
im about to do my rocker cover gasket on my M35 stagea and im just wondering if anyone has a How To on removing and replacing it.
just to make it easyer for myself :D
cheers
Edited by ransom91
https://www.sau.com.au/forums/topic/409646-rocker-cover-gasket-diy/
There's a bit of a DIY on doing the plenum spacer here: http://www.m35stagea...c.php?f=20&t=15.
The pics on putting it back together could be helpful. Otherwise you could take heaps of pics & make up a DIY for those that follow behind..?
But it'll look a bit like this when you pull it apart.
Get some gasket sealant so rubber gasket stars in groove while u put the cover back on. Makes it easier. Watch wires and fitting as heat makes them brittle. Put a bit of rag in turbo intake so no bolts are dropped in there. Good luck bud. Take ur time you will do ok.
Mine needs to be done as well, how long would this take?
I took it too a mechanic and they quoted $258 parts and labour?
The part is less than $30. By asking the question I can assume you aren't a gun mechanic, so the first time you do it will take a lot longer. Allow a couple of hours (max 4) to pull the plenum & ancillary crap off & replace. The last time I did this it took less than an hour to pull down & put back. Everything's heaps easier to remove after being cracked/unstuck previously.
My mechanical skills are pretty basic if that; I change the oil in my bike and do basic stuff like my bike brakes. I looked at the how to and looked pretty busy.
I guess if I take a day off work and take my time I could get it done.
My mechanical skills are pretty basic too :) There is a bit of stuff to remove but nothing is hard. Just keep pulling off bits till you can get to the rocker cover. There are a couple of bolts behind the plenum, but even those aren't very hard to get at. A simple socket set & maybe a couple of spanners is all you need for the whole job.
I wouldn't take a day off work unless you have some sickies owing, haha. A Sat or Sunday arvo is all you need to allocate - you'll be fine :thumbsup:
allgood buddy, its really not as hard as it looks. i came from fords to nissans with small mechanical know how and so far i have done the rocker cover gasket, spark plugs and pulled the drive shafts out and put them back in. its quite easy to work on :D
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
