hey
im about to do my rocker cover gasket on my M35 stagea and im just wondering if anyone has a How To on removing and replacing it.
just to make it easyer for myself :D
cheers
Edited by ransom91
https://www.sau.com.au/forums/topic/409646-rocker-cover-gasket-diy/
There's a bit of a DIY on doing the plenum spacer here: http://www.m35stagea...c.php?f=20&t=15.
The pics on putting it back together could be helpful. Otherwise you could take heaps of pics & make up a DIY for those that follow behind..?
But it'll look a bit like this when you pull it apart.
Get some gasket sealant so rubber gasket stars in groove while u put the cover back on. Makes it easier. Watch wires and fitting as heat makes them brittle. Put a bit of rag in turbo intake so no bolts are dropped in there. Good luck bud. Take ur time you will do ok.
Mine needs to be done as well, how long would this take?
I took it too a mechanic and they quoted $258 parts and labour?
The part is less than $30. By asking the question I can assume you aren't a gun mechanic, so the first time you do it will take a lot longer. Allow a couple of hours (max 4) to pull the plenum & ancillary crap off & replace. The last time I did this it took less than an hour to pull down & put back. Everything's heaps easier to remove after being cracked/unstuck previously.
My mechanical skills are pretty basic if that; I change the oil in my bike and do basic stuff like my bike brakes. I looked at the how to and looked pretty busy.
I guess if I take a day off work and take my time I could get it done.
My mechanical skills are pretty basic too :) There is a bit of stuff to remove but nothing is hard. Just keep pulling off bits till you can get to the rocker cover. There are a couple of bolts behind the plenum, but even those aren't very hard to get at. A simple socket set & maybe a couple of spanners is all you need for the whole job.
I wouldn't take a day off work unless you have some sickies owing, haha. A Sat or Sunday arvo is all you need to allocate - you'll be fine :thumbsup:
allgood buddy, its really not as hard as it looks. i came from fords to nissans with small mechanical know how and so far i have done the rocker cover gasket, spark plugs and pulled the drive shafts out and put them back in. its quite easy to work on :D
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
