I have a "HKS SUPER BLOW OFF VALVE". An old model, not the SSQV. It gives a standard PSCHHT.
- It is mounted between the turbo and the intercooler (not throttle body and intercooler).
- Running only 8-9psi
What is wrong at the moment is that it only vents half the air into the atmosphere, ie. half the air goes back through the system and makes the chuchuchu noise.
The noise it is making atm is Chu-Chu-PSCHHT
What can be the cause of this problem? Vacuum hose too thin? The BOV is either opening too slowly, or opening too late?
Any ideas?
PS> My BOV has two 'outlets' or nipples, I am not sure why it has two, but only one is connected to the vacuum source, the other is left unplugged. Having both T-pieced together renders the BOV useless (I tried before).
https://www.sau.com.au/forums/topic/40966-bov-not-venting-properly/
if it causes alot of flutter the spring tension is probably too tight (if that model does have adjustable tenstion) loosen off the tension bolt and see how you go. if it doesnt get another BOV
infact... just buy my BOV which is for sale! it is adjustable!
http://www.skylinesaustralia.com/forums/sh...ead.php?t=40229
But i know when mine is wound up too tight it flutters, but if i loosen its ok
    • Did you use an electronic speedo drive? Does you speedometer read all the way to 180km?
    • Placing bets on my stock oem RB25 rods, orrrrrrr........?  馃槀馃拃 for anyone interested, Insta is : @genuine_rb13 https://www.instagram.com/genuine_rb13?igsh=MTR5dGh4NWh0NHg3cA==
    • Hahahahah, look, your not wrong 馃槀馃槀 and thank you brother 馃檹馃徏 jokes aside, I haven't driven the car in 6+ years and it's like I'm starting all over again, and furthermore the car is wayyyy more powerful and it's characteristics are night and day different now compared to what I remember. So I'm slowly easing myself back into the groove, the car is literally scaring me a bit tbh.....it feels like it has 200hp more than it does on paper and responds like a cammed Ls v8, and-some! 馃槄 every single bit of throttle pedal travel and input has instant response all the way to the floor, zero flat spots or labouring feelings, it's nuts. Im shooketh, go easy on me hahahaha or don't 馃馃徏馃槉
    • If the house has ever been sold before too, they have photos from that etc.
    • I used to do that, but then I got savvy. The benefits of having your phone photos geotagged outweigh the negatives. I just don't publish any photo straight off the phone/out of the gallery/off google photos, etc. If I'm going to use a photo, other than for SMSing to fam, I will always open it on the computer, copy it/otherwise edit it and save down without the original metadata, before using it. For example, posting photos of my engine bay into a thread on here, to show someone a plug or something - I will just screen-cap the section I want to use and paste that section direct from the clipboard into the post. No metadata goes along with.
