1984 Toyota Tarago V8
I have been thinking about selling this for awhile now, So will put it up to see how it goes, Not fussed if it sells really, but cant really afford so many toys,
I have had this van for about 5 years, The motor conversion has been in it for about 2-3 years, It was originaly a 3Y 4cyl and 5 speed manual...... It was far to slow.......
It now has a mild 308 Holden V8, The motor was built by "The Brock Shop" a few years ago, It has been very well looked after and very regulary serviced,
It has ported heads with bigger valves, springs etc, ACL Flat top pistons, Fairly lumpy cam (unsure specs) Edelbrock performer manifold, 600 Holley, MSD Coil, Crane cams ignition unit, Crane cams electrionic dizzy, hi volume oil pump, Rollmaster timing gear, new hi-torque gear reduction starter motor, brand new balanced flexplate with new ARP bolts, usual good gear, It has a 3000rpm Hi-stall convertor, trimatic auto box, new Hurst pro ratchet shifter, Running Commodore diff (3:23 ratio, open, really needs 3:89) It has twin radiators with thermo fans, stainless steel flexable bottom radiator hose, (sprintcar style)
It is running a twin exhaust, has stock exhaust manifolds (not gotten to modifying extractors yet, But have big ones to go with it) has twin 2.25" exhaust to 2 "Hooker Headers Aero chamber" mufflers, then twin 2.5" tailpipes, sounds great,
The van is currently making about 200rwhp, was making 185rwhp with an extremely restrictive exhaust but is now changed, Will make more as it needs a tune, This will be getting done when I find time etc,
It is Mod plated for the conversion and registered as a 308 with the current motor, Registration due in January 2013,
The van itself does have some rust in the usual Tarago places, and the paint is a rough, few minor dents etc, would need a paint job to look the part again, Also needs a windscreen as it has a crack in it, but makes for an awesome sleeper as is,
I am still fixing it up slowly and will continue to do so untill sold,
It is a pretty cool cruiser and gets lots of looks (many unsure and confused ones) and definatly a whole lot of fun to drive,
It is still an 8 seater van so you can go cruising with 7 of your mates
May swap or part trade with cash either way, open to offers
Will swap drifter, S14, something tough, Make an offer
Asking $4500 ono
(dont offer me $2500 then try to tell me you know more about my car than I do!)
Car is Located in Redlands area, Brisbane, 0481109712
The bullbar is no longer on it but it does come with it if wanted,
Edited by 350stato
  • 4 weeks later...
  • 1 month later...
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
    • The hardcore tracks1ut guys I know would flush their brake fluid every 6 to 12 months depending on the amount of track work they did. Unlike most of us SAU guys, probably flush it once a decade 🥲
    • Now that these are NLA, I suspect the answer is going to be to 3D print the plastic bit and glue on some felt or something to replace the brush. I have one or two of them (new) in the shed to go onto the car at some point. I could put some effort into measuring them up and could attempt to draw up the printed part in FreeCAD, if there is interest.
    • Hey team, the R32 ones look different to the R33 and 200SX ones. Also they're sold out on Amayama, looks like some dealer cleaned up the stock.
    • Might have to @Dose Pipe Sutututu him
