have searched but their seems to be f all info and feeback about itbs for rbs.
So anywhy, went ahead and won this
Rb26 plenumn
Rb26 ITB's
Adapter plate to suit Rb25 head.
Figured i may as well try set this up and see how it goes.
now i havnt recieved it yet but from what ive been reading i can either run off a MAP or TPS sensor, obvious things like tuneable ecu for such and other things like getting vacuum for booster, FRP ect.
From what ive read people either get a vacuum pump or simply set up a vacuum manifold and run a line off each throttle boddie to the chamber then one to booster, frp and whatever else needs it?
Can anyone shed some light onto the situation or put their feedback into this?
Cheers matt.
https://www.sau.com.au/forums/topic/409677-itbs/
You're right, there is f all info out there on them. Didn't stop us from building a setup though.
I've been running ITB's on my rallycar for a few years now and they work a treat. http://www.skylinesdownunder.com/forums/showthread.php?t=52581&page=14
Mine are 4AGE Toyota ones off a 20 Valve, mounted on an adaptor plate and the original intake runners. Cam, head, pistion work etc has leat to a fairly angry little N/A RB20DE. Has taken a few years of tuning and trying things as no one in NZ had done one like this, so it was a bit hit and miss originally.
Mine runs open trumpets with individual filters, so all tuning is done from the TPS, which works fine now.
As far as the brake booster goes I had the same issue with lack of vacuum, made worse by the cams I run. I run a Wilwood dual cylinder pedal box for brake bias, which also means I can run with no booster and it is a good leg work out.
Good luck with the build, even if it does't go faster it will sound fantastic!
https://www.sau.com.au/forums/topic/409677-itbs/#findComment-6543362
will do zebra cheers
awesome work screamin!, sounds pretty throaty. although seems the induction goes away higher in the revs?
Dont have that sort of money for such a brake set up haha, but mine wont be as crazya s what you have done, as you said, im not chasing power, more sound and something different.
What sort of ecu are you running?
Also mine arrived today :D, look pretty good, going to be a fun job.
https://www.sau.com.au/forums/topic/409677-itbs/#findComment-6548500
hey im also interested in something like this for my 25/30.... best option seems to be buying an adapter plate (rips quoted me $500) and using the rb26 bits.... i need a tune anyway so this seems like the best option... if anyone has a setup or something give me the ballpark figure in what im expected to spend ! haha
https://www.sau.com.au/forums/topic/409677-itbs/#findComment-6555543
Took about three years of tuning and racing before we got it really humming. Unlike more conventional RB setups (read turbo) there are no preset maps to start with for the ECU. Stpe one was to make it start, step two idle and so on... For the last five years I've been running this setup I have had the trumpets open with individual filter socks. A real pain having to clean them all the time because of the gravel dust, but clean filters makes a big difference to the power output.
I am planning on getting an airbox built, but am too busy racing it to pull the intake off and make something up, plus it's going alright atm, so no point fixing it...
https://www.sau.com.au/forums/topic/409677-itbs/#findComment-6564325
  • 3 months later...
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
