verger Posted September 19, 2012 Share Posted September 19, 2012 So the car's now gone and i'm left with a bunch of stuff to get rid of! Old post is here - http://www.skylinesa...point-cook-vic/ This is what's left - i've got nothing else apart from what's here! I've also got a box full of nuts and bolts of all sorts so if you're looking for that kind of thing, feel free to ask, or make an offer on the lot! Mirror triangle cover thing - $10 rear wiper motor $20 drum brakes (in bits and pieces) $10 for both Rotors x 4 $70 Pod filter $10 Centre dome light (without cover) $5 front reading lights $10 stock crossover pipe including BOV $20 HICAS computer bits $30 ac pipes $10 blower fan $20 bonnet lining $10 boot hinges and torsion bars $30 bonnet lining $10 boot rear trim light cover $10 brake booster $20 brake pedal $10 engine mounts x 2 $20 centre console hand brake leather $10 centre console front trim $10 cluster surround $20 door sill trims x 2 $10 driver's side kick panel $10 dump pipe (stock) $10 AC evaporator $10 front pipe (stock) $10 fuel tank blanket $0.25 fuel tank strap $0.25 hicas steering rack $30 interior wiring (includes wiring that goes into the boot) $30 jack stands x 4 (only used once! $30 passenger side a pillar trim $10 passenger rear arm rest trim $10 passenger side front fender (has slight bend) $10 passenger side kick panel $10 power steering reservoir minus cap $5 random interior pipes $0.25 rear bar (one scratch, a small ding and a cracked reverse light) $20 rear seat belts $20 rear calipers x 2 $70 roof lining $10 spare wheel cover $10 spare spacesaver wheels x 4 - useful for keeping a shell rolling. 1 is from my skyline, 3 are from falcons (i think?). I used these when i sold my wheels/tyres up until the car ended up on jack stands. $20 each or $50 the lot steering column (minus the bottom part of the shaft) $40 tail lights $40 each under-dash bar thing $10 under steering wheel trim $10 under windscreen cover $10 front wiper motor $20 fuel pump $20 Headlight wiring loom minus front indicator plugs $20 side mirrors $40 each (driver's side has a small crack on the side) alternator - had battery juice spilt on it from the accident, might still work $10 bonnet seal $0.50 boost sensor $5 boot lid lock and latch $10 boot rubber seal $10 various boot trim clips $5 castor rod arms $20 each catalytic convertor sensor $10 centre console brackets $1 centre dome light without cover $5 dash dimmer $10 door seal (the hard one, not the soft rubber one) - i think it's the driver's side $10 driver door loom $5 washer bottle loom $5 ignition loom $10 driver side door solonoid $10 flywheel cover $10 front control arms x 2 $40 front windscreen washers $5 hazard/stereo switch $20 ignition/headlight reminder beeper $5 number plate lights $5 (or free with the front bar) open door sensors $10 outer door handles $20 each passenger fog light (lens is ok, plastic a little cracked) $10 hicas module $30 stock rear audio amplifier $5 sun visor clips $5 various metal sheild bits $10 the lot various trims $name your price wiper amp $5 wiper switch $20 Hover your mouse over the images below - the descriptions are in the filename which will pop up - [ Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/ Share on other sites More sharing options...
verger Posted September 19, 2012 Author Share Posted September 19, 2012 Also note that I work in St Kilda near the St Kilda junction, so if you want to pick up from there instead, that can be arranged from about 9am to 6pm weekdays. I'll post anything (except for the larger, fragile items like the front guard and rear bar) at the buyer's expense. Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6541696 Share on other sites More sharing options...
verger Posted September 20, 2012 Author Share Posted September 20, 2012 All PMs replied to. Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6542133 Share on other sites More sharing options...
verger Posted September 20, 2012 Author Share Posted September 20, 2012 Boost sensor gone! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6542217 Share on other sites More sharing options...
verger Posted September 20, 2012 Author Share Posted September 20, 2012 All PMs replied to! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6542310 Share on other sites More sharing options...
verger Posted September 20, 2012 Author Share Posted September 20, 2012 Engine mounts gone! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6543499 Share on other sites More sharing options...
verger Posted September 21, 2012 Author Share Posted September 21, 2012 Jack stands gone! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6544012 Share on other sites More sharing options...
verger Posted September 21, 2012 Author Share Posted September 21, 2012 AC pipes gone! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6545044 Share on other sites More sharing options...
verger Posted September 25, 2012 Author Share Posted September 25, 2012 Bump! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6550599 Share on other sites More sharing options...
verger Posted October 2, 2012 Author Share Posted October 2, 2012 Bump! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6560427 Share on other sites More sharing options...
soultz Posted October 6, 2012 Share Posted October 6, 2012 mate PM me your number ASAP i need the rotors! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6566817 Share on other sites More sharing options...
poo32 Posted October 6, 2012 Share Posted October 6, 2012 Are you selling the diff? If so what specs? Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6567122 Share on other sites More sharing options...
verger Posted October 6, 2012 Author Share Posted October 6, 2012 Are you selling the diff? If so what specs? No that's gone. I've only got what's left in the list above. Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6567227 Share on other sites More sharing options...
verger Posted October 10, 2012 Author Share Posted October 10, 2012 Front brake discs are 30mm so they're roadworthy, but the rears are only 17mm - apparently that isn't roadworthy. (it's an 18mm minimum so i've heard). Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6572189 Share on other sites More sharing options...
justinG Posted October 11, 2012 Share Posted October 11, 2012 Mate do you have the rear windscreen by any chance? Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6573882 Share on other sites More sharing options...
verger Posted October 11, 2012 Author Share Posted October 11, 2012 Mate do you have the rear windscreen by any chance? No that's gone sorry. Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6573926 Share on other sites More sharing options...
verger Posted October 11, 2012 Author Share Posted October 11, 2012 Spare wheel cover gone! various boot trim clips gone! rear strut plastic top cover thing gone! (have one left) Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6574592 Share on other sites More sharing options...
verger Posted October 14, 2012 Author Share Posted October 14, 2012 Front left guard gone! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6578826 Share on other sites More sharing options...
verger Posted October 15, 2012 Author Share Posted October 15, 2012 4 x rotors - gone! passenger side front guard - gone! crossover pipe + bov - gone! boot hinges + torsion bars - gone! boot lid lock and latch - gone! Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6580103 Share on other sites More sharing options...
Mohsen Posted October 16, 2012 Share Posted October 16, 2012 Still got the dash and head unit surround? Link to comment https://www.sau.com.au/forums/topic/409682-vic-garage-cleanout-random-stock-1993-r32-gts-t-parts-in-point-cook/#findComment-6581369 Share on other sites More sharing options...
