So the car's now gone and i'm left with a bunch of stuff to get rid of!
Old post is here - http://www.skylinesa...point-cook-vic/
This is what's left - i've got nothing else apart from what's here! I've also got a box full of nuts and bolts of all sorts so if you're looking for that kind of thing, feel free to ask, or make an offer on the lot!
Mirror triangle cover thing - $10
rear wiper motor $20
drum brakes (in bits and pieces) $10 for both
Rotors x 4 $70
Pod filter $10
Centre dome light (without cover) $5
front reading lights $10
stock crossover pipe including BOV $20
HICAS computer bits $30
ac pipes $10
blower fan $20
bonnet lining $10
boot hinges and torsion bars $30
bonnet lining $10
boot rear trim light cover $10
brake booster $20
brake pedal $10
engine mounts x 2 $20
centre console hand brake leather $10
centre console front trim $10
cluster surround $20
door sill trims x 2 $10
driver's side kick panel $10
dump pipe (stock) $10
AC evaporator $10
front pipe (stock) $10
fuel tank blanket $0.25
fuel tank strap $0.25
hicas steering rack $30
interior wiring (includes wiring that goes into the boot) $30
jack stands x 4 (only used once! :) $30
passenger side a pillar trim $10
passenger rear arm rest trim $10
passenger side front fender (has slight bend) $10
passenger side kick panel $10
power steering reservoir minus cap $5
random interior pipes $0.25
rear bar (one scratch, a small ding and a cracked reverse light) $20
rear seat belts $20
rear calipers x 2 $70
roof lining $10
spare wheel cover $10
spare spacesaver wheels x 4 - useful for keeping a shell rolling. 1 is from my skyline, 3 are from falcons (i think?). I used these when i sold my
wheels/tyres up until the car ended up on jack stands. $20 each or $50 the lot
steering column (minus the bottom part of the shaft) $40
tail lights $40 each
under-dash bar thing $10
under steering wheel trim $10
under windscreen cover $10
front wiper motor $20
fuel pump $20
Headlight wiring loom minus front indicator plugs $20
side mirrors $40 each (driver's side has a small crack on the side)
alternator - had battery juice spilt on it from the accident, might still work $10
bonnet seal $0.50
boost sensor $5
boot lid lock and latch $10
boot rubber seal $10
various boot trim clips $5
castor rod arms $20 each
catalytic convertor sensor $10
centre console brackets $1
centre dome light without cover $5
dash dimmer $10
door seal (the hard one, not the soft rubber one) - i think it's the driver's side $10
driver door loom $5
washer bottle loom $5
ignition loom $10
driver side door solonoid $10
flywheel cover $10
front control arms x 2 $40
front windscreen washers $5
hazard/stereo switch $20
ignition/headlight reminder beeper $5
number plate lights $5 (or free with the front bar)
open door sensors $10
outer door handles $20 each
passenger fog light (lens is ok, plastic a little cracked) $10
hicas module $30
stock rear audio amplifier $5
sun visor clips $5
various metal sheild bits $10 the lot
various trims $name your price
wiper amp $5
wiper switch $20
Hover your mouse over the images below - the descriptions are in the filename which will pop up -
post-49595-0-97266400-1348061831_thumb.jpgpost-49595-0-07195400-1348061836_thumb.jpgpost-49595-0-18719900-1348061840_thumb.jpgpost-49595-0-78787000-1348061846_thumb.jpgpost-49595-0-94654000-1348061851_thumb.jpgpost-49595-0-76036200-1348061856_thumb.jpgpost-49595-0-94840300-1348061860_thumb.jpgpost-49595-0-45373100-1348061867_thumb.jpgpost-49595-0-72708000-1348061872_thumb.jpgpost-49595-0-83452600-1348061877_thumb.jpg[post-49595-0-06683200-1348062174_thumb.jpgpost-49595-0-81306900-1348062181_thumb.jpgpost-49595-0-14020400-1348062185_thumb.jpgpost-49595-0-38362200-1348062191_thumb.jpgpost-49595-0-25074200-1348062196_thumb.jpgpost-49595-0-74292100-1348062200_thumb.jpgpost-49595-0-69283900-1348062205_thumb.jpgpost-49595-0-69241500-1348062209_thumb.jpgpost-49595-0-28226100-1348062214_thumb.jpgpost-49595-0-11974900-1348062245_thumb.jpgpost-49595-0-65492000-1348062248_thumb.jpgpost-49595-0-17601200-1348062253_thumb.jpgpost-49595-0-54064800-1348062257_thumb.jpgpost-49595-0-05342900-1348062262_thumb.jpgpost-49595-0-51312400-1348062265_thumb.jpgpost-49595-0-75468200-1348062270_thumb.jpgpost-49595-0-66857600-1348062275_thumb.jpgpost-49595-0-16849000-1348062280_thumb.jpgpost-49595-0-66312300-1348062284_thumb.jpgpost-49595-0-78320700-1348062353_thumb.jpgpost-49595-0-84767400-1348062358_thumb.jpgpost-49595-0-88934400-1348062362_thumb.jpgpost-49595-0-04651400-1348062365_thumb.jpgpost-49595-0-20698200-1348062367_thumb.jpgpost-49595-0-07607100-1348062371_thumb.jpgpost-49595-0-25783000-1348062373_thumb.jpgpost-49595-0-67889900-1348062376_thumb.jpgpost-49595-0-86932100-1348062378_thumb.jpgpost-49595-0-30793900-1348062382_thumb.jpgpost-49595-0-49850700-1348062622_thumb.jpgpost-49595-0-69623400-1348062624_thumb.jpgpost-49595-0-99086400-1348062626_thumb.jpgpost-49595-0-10704600-1348062629_thumb.jpgpost-49595-0-40356000-1348062631_thumb.jpgpost-49595-0-38345200-1348062633_thumb.jpgpost-49595-0-02602600-1348062635_thumb.jpgpost-49595-0-24273900-1348062637_thumb.jpgpost-49595-0-32352600-1348062642_thumb.jpgpost-49595-0-60335200-1348062644_thumb.jpgpost-49595-0-72434200-1348062697_thumb.jpgpost-49595-0-05352900-1348062700_thumb.jpgpost-49595-0-39537800-1348062702_thumb.jpgpost-49595-0-79666900-1348062704_thumb.jpgpost-49595-0-07167800-1348062707_thumb.jpgpost-49595-0-57441500-1348062709_thumb.jpgpost-49595-0-13499800-1348062712_thumb.jpgpost-49595-0-32040300-1348062714_thumb.jpgpost-49595-0-43085200-1348062716_thumb.jpgpost-49595-0-74347700-1348062719_thumb.jpgpost-49595-0-75005600-1348062796_thumb.jpgpost-49595-0-89449300-1348062798_thumb.jpgpost-49595-0-30280100-1348062801_thumb.jpgpost-49595-0-44030700-1348062803_thumb.jpgpost-49595-0-40430900-1348062805_thumb.jpgpost-49595-0-68033500-1348062807_thumb.jpgpost-49595-0-20386400-1348062809_thumb.jpgpost-49595-0-40002400-1348062811_thumb.jpgpost-49595-0-50849600-1348062813_thumb.jpgpost-49595-0-81706300-1348062815_thumb.jpgpost-49595-0-23306300-1348062867_thumb.jpgpost-49595-0-32260800-1348062869_thumb.jpgpost-49595-0-76539800-1348062871_thumb.jpgpost-49595-0-91949300-1348062873_thumb.jpgpost-49595-0-28136400-1348062876_thumb.jpgpost-49595-0-40875400-1348062878_thumb.jpgpost-49595-0-56440300-1348062880_thumb.jpgpost-49595-0-04427300-1348062883_thumb.jpgpost-49595-0-40983800-1348062885_thumb.jpgpost-49595-0-83439300-1348062887_thumb.jpgpost-49595-0-25158700-1348062932_thumb.jpgpost-49595-0-34752500-1348062934_thumb.jpgpost-49595-0-36401100-1348062936_thumb.jpgpost-49595-0-52685800-1348062938_thumb.jpgpost-49595-0-30987700-1348062941_thumb.jpgpost-49595-0-43684400-1348062943_thumb.jpgpost-49595-0-72175800-1348062945_thumb.jpgpost-49595-0-95165400-1348062947_thumb.jpgpost-49595-0-89140200-1348062951_thumb.jpgpost-49595-0-02960100-1348062954_thumb.jpgpost-49595-0-26918500-1348062988_thumb.jpgpost-49595-0-50217900-1348062990_thumb.jpgpost-49595-0-09646500-1348062992_thumb.jpgpost-49595-0-34989200-1348062994_thumb.jpgpost-49595-0-85686900-1348062996_thumb.jpgpost-49595-0-25008100-1348062999_thumb.jpgpost-49595-0-79433400-1348063002_thumb.jpgpost-49595-0-93560800-1348063004_thumb.jpgpost-49595-0-10501700-1348063007_thumb.jpgpost-49595-0-32023400-1348063009_thumb.jpg
  • Replies 40
Also note that I work in St Kilda near the St Kilda junction, so if you want to pick up from there instead, that can be arranged from about 9am to 6pm weekdays. I'll post anything (except for the larger, fragile items like the front guard and rear bar) at the buyer's expense.
Front brake discs are 30mm so they're roadworthy, but the rears are only 17mm - apparently that isn't roadworthy. (it's an 18mm minimum so i've heard).
4 x rotors - gone!
passenger side front guard - gone!
crossover pipe + bov - gone!
boot hinges + torsion bars - gone!
boot lid lock and latch - gone!
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
