  • Replies 40
UPDATED LIST!!! PRICE DROP!!!
various trims $name your price
centre console brackets $1
power steering reservoir minus cap $5
centre dome light without cover $5
driver door loom $5
washer bottle loom $5
number plate lights $5
front windscreen washers $5
ignition/headlight reminder beeper $5
stock rear audio amplifier $5
sun visor clips $5
wiper amp $5
Mirror triangle cover thing - $10
drum brakes (in bits and pieces) $10 for both
Pod filter $10
front reading lights $10
HICAS computer bits $10
blower fan $10
bonnet lining $10
brake booster $10
brake pedal $10
centre console hand brake leather $10
centre console front trim $10
door sill trims x 2 $10
driver's side kick panel $10
dump pipe (stock) $10
AC evaporator $10
front pipe (stock) $10
hicas steering rack $10
passenger side a pillar trim $10
passenger rear arm rest trim $10
passenger side kick panel $10
roof lining $10
steering column (minus the bottom part of the shaft) $10
under-dash bar thing $10
under steering wheel trim $10
under windscreen cover $10
alternator - had battery juice spilt on it from the accident, might still work $10
boot rubber seal $10
catalytic convertor sensor $10
dash dimmer $10
door seal (the hard one, not the soft rubber one) - i think it's the driver's side $10
ignition loom $10
driver side door solonoid $10
flywheel cover $10
open door sensors $10
passenger fog light (lens is ok, plastic a little cracked) $10
various metal sheild bits $10 the lot
wiper switch $20
rear wiper motor $20
cluster surround $20
interior wiring (includes wiring that goes into the boot) $30
rear seat belts $20
hazard/stereo switch $20
outer door handles $20 each
fuel pump $20
Headlight wiring loom minus front indicator plugs $20
castor rod arms $20 each
hicas module $30
side mirrors $40 each (driver's side has a small crack on the side)
front control arms x 2 $40
rear calipers x 2 $70
Passenger side mirror gone!
centre console/handbrake surround gone!
2 x kick panels gone!
passenger side a pillar trim gone!
seat belt bolt covers gone!
passenger side rear seat hand rest panel gone!
  • 1 month later...
The remaining parts have been listed as a $1 NO RESERVE eBay auction - http://cgi.ebay.com....em=261147664144
I want this stuff gone! Happy bidding!!!
Only 3 hours left until the auction closes (see link above) and that's all the parts gone from my wreck! Get your bids in or miss out!
LAST CHANCE!!!!
