  • Replies 40
UPDATED LIST!!! PRICE DROP!!!
various trims $name your price
centre console brackets $1
power steering reservoir minus cap $5
centre dome light without cover $5
driver door loom $5
washer bottle loom $5
number plate lights $5
front windscreen washers $5
ignition/headlight reminder beeper $5
stock rear audio amplifier $5
sun visor clips $5
wiper amp $5
Mirror triangle cover thing - $10
drum brakes (in bits and pieces) $10 for both
Pod filter $10
front reading lights $10
HICAS computer bits $10
blower fan $10
bonnet lining $10
brake booster $10
brake pedal $10
centre console hand brake leather $10
centre console front trim $10
door sill trims x 2 $10
driver's side kick panel $10
dump pipe (stock) $10
AC evaporator $10
front pipe (stock) $10
hicas steering rack $10
passenger side a pillar trim $10
passenger rear arm rest trim $10
passenger side kick panel $10
roof lining $10
steering column (minus the bottom part of the shaft) $10
under-dash bar thing $10
under steering wheel trim $10
under windscreen cover $10
alternator - had battery juice spilt on it from the accident, might still work $10
boot rubber seal $10
catalytic convertor sensor $10
dash dimmer $10
door seal (the hard one, not the soft rubber one) - i think it's the driver's side $10
ignition loom $10
driver side door solonoid $10
flywheel cover $10
open door sensors $10
passenger fog light (lens is ok, plastic a little cracked) $10
various metal sheild bits $10 the lot
wiper switch $20
rear wiper motor $20
cluster surround $20
interior wiring (includes wiring that goes into the boot) $30
rear seat belts $20
hazard/stereo switch $20
outer door handles $20 each
fuel pump $20
Headlight wiring loom minus front indicator plugs $20
castor rod arms $20 each
hicas module $30
side mirrors $40 each (driver's side has a small crack on the side)
front control arms x 2 $40
rear calipers x 2 $70
Passenger side mirror gone!
centre console/handbrake surround gone!
2 x kick panels gone!
passenger side a pillar trim gone!
seat belt bolt covers gone!
passenger side rear seat hand rest panel gone!
  • 1 month later...
The remaining parts have been listed as a $1 NO RESERVE eBay auction - http://cgi.ebay.com....em=261147664144
I want this stuff gone! Happy bidding!!!
Only 3 hours left until the auction closes (see link above) and that's all the parts gone from my wreck! Get your bids in or miss out!
LAST CHANCE!!!!
    • Yeah I spent close to a year finding one. I was even tempted to buy a RB25DE N/A head and port it out. That latter option, could still be an option.
    • My head recently blew up on the dyno, been trying to find a replacement for the last 3 months with no luck.  Does anyone know where I might be able to find one? Willing to chase down any leads at this point  Cheers
    • Waiting for a queue of Supras to get out of the way. Then the same conversion work to the box which was probably bought about the same day as you bought yours, by the sound of it. And hopefuly with enough Supras out of the way we'll finally get to do the box into the car along with the injectors and AFM so that the last 18 months of driving a highflow nearly NA can finally come to an end.
    • That was a long winded way to say yes....
    • Got my R34 gearbox around 4-5 weeks ago. Came into some extra $$ recently and after I cleaned the mess off the notes, I thought, might as well buy that R34 box I've been pondering.  In that time I've pulled the engine out, replaced rod and mains bearings, done a few other engine things that are much easier with the engina out eg PRP oil pump upgrade, replacing wastegate coolant lines, installing Turbosmartass turbo oil pressure reg, made some mounting brackets for some of my mods that are "hard to reach", converted the R34 box to R33, put the engine and new gearbox back in the car. Plus cleaning ...Oh my god so much cleaning when doing such a project. Yep I'm a busy bee, buzz buzz. As part of the gearbox project, researched posts and found this thread (In which i nailed it for the OP), hence the post here # logical thinking.. Not all about you old boy, SOrrryyy. Dare I ask,  how's yours going ,> Or you got it done yet, and if so why didn't you post any of the tips I posted to help other members? ???
