Location: Newcastle Nsw but can freight anywhere in Australia
Item : Rb25det Engine
Complete Rb25det with all sensors, turbo, manual ecu and harness etc so if theres anything not listed just ask
Comp tested all within 3 psi of each other but a big of a noise in top end. Stickly lifter maybe engine blew no smoke and ran perfect other then noise
Stripping down to long engine but can disassemble more if required
Intercooler piping set $120
Gfb Deceptor Bov ( no in cabin switch only loom) $260
Drift air filter with adaptor $40
Airflow meter $100
Manual Ecu $120
Engine Harness $165
Injectors and rail $160
Stock turbo with dump and shields $275
Stock Manifold $60
Stock air intake pipe $50
ac compressor $100
Alternator $100
Starter motor $100
Coilpacks $25 each
Coilpack cover $75
Throttle body $60
Tps $45
Plenium stock $75
Drive belts $10 each
Long engine $850
Anything else just ask
Having dramas loading a pic ill load one via photobucket tomorrow.
0402555849
https://www.sau.com.au/forums/topic/409687-parting-out-rb25det-series-2-engine/
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
