hey all my car is going in at 1 pm today for a new clutch fan and a service but after reading idk if i need a new fan my local nissan mechanic said that the fan dosnt disengage so i went out and had i play when i start my car its on max and makes like a quite howling but when i put it into gear my hole car gos quite also when i drive its sounds like a quite bus and its kinda hard to turn by hand if ya spin it will just stop 2 blades down if ya know what i mean cheers :cheers:
edit. car dosnt over heat
https://www.sau.com.au/forums/topic/409695-r34-clutch-fan-need-help-asap/
I would suggest you take it to a workshop that specializes in imports mate. They would be able to tell you what is happening within a few minutes as they have prob seen this sort of thing before.
No point in replacing something that prob doesn't need to be replaced.
Sounds like the clutch fan is locked and in need of replacement i guess, the howling means its locked....... How much did they quote you for one?
280 for new fan new fan shroud and a small rocket cover leak
Also dude, it would just be cam cover gaskets..... There is a really funny image on Rocket cover vs Rocker cover but i cant find it, i found one for you to enjoy :D
No offense intended, just helping :)
kk cheers all guess il let them do it 280 ant much
It sounds pretty pricey, if you have the time ring around and get some other quotes just to make sure you are getting the best deal you can :)
lol i neva new that learn sumthing everyday but in saying that its a 34 so there rockets in there some where ha!!
Hahaha i dunno about rockets mate..... Mine does sound like a bit of a jet now though :D
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
