Hey guys,
So here's the run down.
Tuesday when the partner took her car (Daihatsu Charade 1996) out of the driveway i noticed a small puddle of Radiator coolant, I had filled it up 2 days prior and thought it might be from the filling up process or extra that had come through the reservoir.
Come wednesday night, partner drives home and tells me after dinner that the temp gauge on the Charade was on "H", I asked how far, she said the whole way.
I decided to go have a look at to my suprise, there was no coolant left in the radiator. Now to be fair, there was still about <500ml left in there when i dropped the coolant via the drain plug. Because the temp sensor requires coolant to be in there in order to have a reading it wasnt completely empty.
I proceeded to fill up the radiator with water temporarily (11pm at night).
I then moved to the oil, now, the oil was just below the full point when i checked it on Monday. Right now it was sitting below the low point clearly indicating that the engine had overheated and that it began to burn oil.
I proceeded to fill up the engine with oil till the dipstick read Full.
I then attempted to give the car a start to let the oil run and take another reading, and to my dismay the car would crank but not start.
I checked the fuel pump fuse, replaced the battery. With no luck.
When I turn the key, I dont think i can hear the fuel pump engaging. But i will need to double check that since there is a fair few things in the boot that will not allow me to hear it, or it is just inaudible.
I have a to do list tonight:
Check the spark plugs and test it using a jumper lead.
Test the spark plug leads.
Let the spark plugs out and let the engine "air out" to eliminate the possibility of me flooding the engine.
OR
Take all the plugs out and give it a little crank and let the excess fuel, if any, spurt out.
Spray some Starting Fluid into the throttle and give it a start to see if that works. If it does then something to do with the fuel.
Is there anything else someone can please recommend?
Car Specs
1996 Daihatsu Charade G203 (Auto) (EFI)
Bought the car only a month ago so my partner can have a little run around (new license holder)
Previous owner claimed it had been serviced 3 weeks ago, which i highly doubt now. Shouldn't have been lazy and done the service the first day i picked up the car.
Any help would be appreciated guys.
Cheers,
Vik
https://www.sau.com.au/forums/topic/409716-cranks-but-no-start/
Hey guys,
OR
Car Specs
Cheers,
Vik
The normal checks
No spark
No fuel
No air
In this case more then likely a head gasket at the least , those cars are " disposable junk" sorry to be so frank but even new they sucked and dependability was suss lots of lemons
You know the engine cooked , might as well proceed to compression test it , but 99% sure its stuffed low oil and no water is fatal on alloy heads
Not all sensors need water to register if they get hot enough it still pegs the needle without water if its mounted on engine block and not in hose , the boiling vapor can max it out or metal parts
yank the plugs , do you know anyone with bore cam like stupid cheap sells ? Take a look inside the pistons , most likely scored the walls too or glazed the bores badly
Best of luck but my guess its dead if driven a while pegged ?
Last time I blew a heater hose, I ended up warping the head (this was the RB20DET). I reckon your lady's car has done the same. A compression test should confirm - 2 & 3 will be very low compression.
Well dad's coming over on Saturday and we will rip the head off and have a look. In the meantime, checked the sparks and leads all good. Sprayed some starter fluid in the intake and it turned over and started fine.
I have a feeling there might be a problem with the fuel pump because its caused problems before.
Might be just a coincidence.
Certainly hope so :(
Vik.
Does it sound like it still has compression? If its EFI just pull the fuel line off and turn the key to see if the pump primes? (Its a bogan way to do it but it works, just aim the fuel line into a bucket or something lol)
Im pretty sure the Fuel Pump has called it a day.
When i engage and put "the reds" on I can't hear it at all. Im actually gonna' slightly undo the fuel rail bolt and see if anything squirts out.
What's the best way to diagnose a possible warped head ?
Yeah agree if you had a fuel problem before sort that first clogged filter maybe simple ? Bad fuel ?
you may just be lucky as hell and it didn't die ? blown head is easy compression test, leak down or bubbles in coolant oil in coolant or in combustion chamber
Dont rip it down yet if it runs unless you hear horrible noises lol
Hey hows it goin' guys.
Well I got it started on the weekend (ghetto job, bypassed fuel pump using a cannister full of fuel and another fuel pump). It started perfectly fine with no hassles. Engine is fine, no damage to the head (thank god!)
The radiator leak is coming from the Water Pump which requires the engine to be dropped in order to access it. The Fuel Pump is in Tank and will need to be dropped as there is no access point under the seat.
Now, this is going to take over 4 hours to do on the weekend, considering just sending it to a garage, how much do you reckon labor charges would be if i supply the parts?
Cheers
Cheers
More then the cars worth lol sorry
Labour rates vary but most at least 100 hr
front wheel drive is a hassle on repairs lol
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
