Hey guys,
So here's the run down.
Tuesday when the partner took her car (Daihatsu Charade 1996) out of the driveway i noticed a small puddle of Radiator coolant, I had filled it up 2 days prior and thought it might be from the filling up process or extra that had come through the reservoir.
Come wednesday night, partner drives home and tells me after dinner that the temp gauge on the Charade was on "H", I asked how far, she said the whole way.
I decided to go have a look at to my suprise, there was no coolant left in the radiator. Now to be fair, there was still about <500ml left in there when i dropped the coolant via the drain plug. Because the temp sensor requires coolant to be in there in order to have a reading it wasnt completely empty.
I proceeded to fill up the radiator with water temporarily (11pm at night).
I then moved to the oil, now, the oil was just below the full point when i checked it on Monday. Right now it was sitting below the low point clearly indicating that the engine had overheated and that it began to burn oil.
I proceeded to fill up the engine with oil till the dipstick read Full.
I then attempted to give the car a start to let the oil run and take another reading, and to my dismay the car would crank but not start.
I checked the fuel pump fuse, replaced the battery. With no luck.
When I turn the key, I dont think i can hear the fuel pump engaging. But i will need to double check that since there is a fair few things in the boot that will not allow me to hear it, or it is just inaudible.
I have a to do list tonight:
Check the spark plugs and test it using a jumper lead.
Test the spark plug leads.
Let the spark plugs out and let the engine "air out" to eliminate the possibility of me flooding the engine.
OR
Take all the plugs out and give it a little crank and let the excess fuel, if any, spurt out.
Spray some Starting Fluid into the throttle and give it a start to see if that works. If it does then something to do with the fuel.
Is there anything else someone can please recommend?
Car Specs
1996 Daihatsu Charade G203 (Auto) (EFI)
Bought the car only a month ago so my partner can have a little run around (new license holder)
Previous owner claimed it had been serviced 3 weeks ago, which i highly doubt now. Shouldn't have been lazy and done the service the first day i picked up the car.
Any help would be appreciated guys.
Cheers,
Vik
https://www.sau.com.au/forums/topic/409716-cranks-but-no-start/
Hey guys,
OR
Car Specs
Cheers,
Vik
The normal checks
No spark
No fuel
No air
In this case more then likely a head gasket at the least , those cars are " disposable junk" sorry to be so frank but even new they sucked and dependability was suss lots of lemons
You know the engine cooked , might as well proceed to compression test it , but 99% sure its stuffed low oil and no water is fatal on alloy heads
Not all sensors need water to register if they get hot enough it still pegs the needle without water if its mounted on engine block and not in hose , the boiling vapor can max it out or metal parts
yank the plugs , do you know anyone with bore cam like stupid cheap sells ? Take a look inside the pistons , most likely scored the walls too or glazed the bores badly
Best of luck but my guess its dead if driven a while pegged ?
Last time I blew a heater hose, I ended up warping the head (this was the RB20DET). I reckon your lady's car has done the same. A compression test should confirm - 2 & 3 will be very low compression.
Well dad's coming over on Saturday and we will rip the head off and have a look. In the meantime, checked the sparks and leads all good. Sprayed some starter fluid in the intake and it turned over and started fine.
I have a feeling there might be a problem with the fuel pump because its caused problems before.
Might be just a coincidence.
Certainly hope so :(
Vik.
Does it sound like it still has compression? If its EFI just pull the fuel line off and turn the key to see if the pump primes? (Its a bogan way to do it but it works, just aim the fuel line into a bucket or something lol)
Im pretty sure the Fuel Pump has called it a day.
When i engage and put "the reds" on I can't hear it at all. Im actually gonna' slightly undo the fuel rail bolt and see if anything squirts out.
What's the best way to diagnose a possible warped head ?
Yeah agree if you had a fuel problem before sort that first clogged filter maybe simple ? Bad fuel ?
you may just be lucky as hell and it didn't die ? blown head is easy compression test, leak down or bubbles in coolant oil in coolant or in combustion chamber
Dont rip it down yet if it runs unless you hear horrible noises lol
Hey hows it goin' guys.
Well I got it started on the weekend (ghetto job, bypassed fuel pump using a cannister full of fuel and another fuel pump). It started perfectly fine with no hassles. Engine is fine, no damage to the head (thank god!)
The radiator leak is coming from the Water Pump which requires the engine to be dropped in order to access it. The Fuel Pump is in Tank and will need to be dropped as there is no access point under the seat.
Now, this is going to take over 4 hours to do on the weekend, considering just sending it to a garage, how much do you reckon labor charges would be if i supply the parts?
Cheers
Cheers
More then the cars worth lol sorry
Labour rates vary but most at least 100 hr
front wheel drive is a hassle on repairs lol
    • To plug the hole. The engine plant may not have known whether the car it was going into had a gauge or not. It was a long time ago and the integrations might not have been fully modern. Or they might not have cared because the extra inventory and processes to save a few cents on the sender might have cost more anyway. But please tell me you are not still confusing the idea of a pressure gauge sender, and an oil pressure light switch. The switch will be out there. In a separate hole. Probably with only one wire running to it. Running the light.
    • Blower needs to go low on the exhaust side, displacing the AC and PS, which you have to decide whether you want to keep and how and where to relocate if you do. Electric option for PS is, at least, helpful. Sadly, there is no workable 12V electric AC of any value. Whilst the blower is the last compression step before the throttle, and so it might seem a good idea to have it near the inlet manifold (as mentioned above), you probably want it to go through an intercooler first, so, having it on the opposite side of the car facilitates that air flow path. The turbo discharges into the blower, so proximity of the turbo's compressor outlet to the blower's inlet is nice. But then you might want to intercool that too, before boosting it again....which would probably be a ball ache. Routing pipes out to the front and back could be a bit shit. If there was room for (at least) a small (but preferably larger) water to air core on that side, then that would probably be the best approach. I guess a reasonable alternative would be to locate the blower where the alternator is (more or less, associated with the inlet manifold, per Matt's thought), and somehow incorporate a water to air core into the manifold, sort of like they do for modern blown V8s. The big difference here though is that those V8s have only the one throttle (upstream the blower) and only the one compression step (the blower) and no need for too much in the way of bypass/blowoff valves. Whereas in a twin charged 6, you do need to think about one or two bypass valves associated with the 2 compressors and you would prefer to have the intercooling done before the air has to pass through the throttle. You'd like the throttle to work approx the same no matter what the compression is doing. But if it is located in hot air stream before a cooler, then sometimes the air will be real hot, sometimes it will be quite cool, and the throttle mapping/response will be quite different between those two cases. The throttle, if sized for hot air, would be too large for cold conditions. It's all a ball ache.
    • Package SC on exhaust side. Remote mount turbo. Still a fair bit of room when you get creative on the inlet side of the motor too. Especially if you can get really creative with the welding, and effectively build it into the bottom of the inlet manifold. Would definitely take some design work, and some trial and error, to make sure flow works well still! Might be easier to just start with the Nissan March though... All the work is already done for you...
    • I'll sit down and get a post together 馃榿
    • The factory oil pressure sender is no longer in the car that's what is confusing me. In the Taarks adapter I have an aftermarket Bosch style pressure/temp sender and the factory temp sender only. Oil pressure is perfect. Where does the factory oil temp sender go to if there were never any gauges? Why was it there from the factory?
