I didnt do it myself but the guy who i bought it off. Everything seems fine with the engine, but the car is running way too rich...so much smoke and smell.The engine is running low compression pistons since its was originally a rb20det. What can i do? put non turbo injectors and/or change the fuel pump?
  • Replies 46
Injectors etc probably arent going to help, more likely an ECU will...... But i must ask WHY did he remove the turbo? The RB20DET - T would be terrible to drive? (No offense)
crap power low end but it picks up like a skyline should after like 5500rpm. BTW i think there is already an ecu..u cant just take the turbo off and expect your car to run...it wont!
Oh it'll run just fine.
Might be a lil' rich though.
an NA that piks up after 5500. Far out. your on p's by the sound of it?
the only money id spend on that is to get a rb25de and bolt in.
you think there is an ECU? is this car on bricks?
go fist yourself, i want to drive a non turbo r32, f**k me right? i dont care ive been looking for a factory gts for a while now and most of them are either auto or are really expensive. They are rare...more and more r32's are off the street nowadays. The car drives fine, it just runs rich.
You said its got a non turbo computer? What colour are the injectors? pink or red?
Also a rooted o2 sensor will cause this.
injectors are greyish black
here's a picture of the ecu...it looks aftermarket : http://imgur.com/2UWCH
Looks like the NISTUNE logo and Envy Dyno.......
ye i told you it had an different computer
id also like to mention im still using the factory turbo manifold...its been modified to go straight to the dump pipe. Maybe its a bit restrictive? getting different headers will be one of the first mods id do.
haha, hit a sore point did i mate?
Sorry, your car is not rare. But... What you could do.Is grab a NA rb25de for Say $500, Bolt it in. Not only will you have a stock DE motor, But will be able to enjoy the extra .5 Lt. Win win is it not?
Otherwise you could spend money on what you currently have....And still be drving around in a low comp 2L NA
Edited by sydking
and pay thousands to get it engineered? no thanks bro
Edited by IM-32-FK
Definetly buy a rb25de motor, cheap as compared to fixing yours to run properly as will only take a day to fit of you have some knowledge. Also will go way quicker than what's in there now
Hmmm, you should watch what you are talking about. As for his suggestion of putting a proper non turbo motor in there is the smartest decision you will ever make.
As for why your car is running shit? Its because the turbo is missing doofus. And want to know another thing? Your non turbo'd car is still illegal for you to drive on your p's because it was registered as a turbo.
So instead of spitting in people's faces like a spoilt brat, just take what he says and reply in a manner as follows, no thank you, I would rather try something else
lol u driving a non turbo 4 wheel drive r33 ROFL what a joke why bother having 4 wheel drive when your car dont even have power lolololololol
Doesn't need to be engineered as its a factory motor designed for that chassis. Also awd helps heaps in wet, I know my rwd r33 has stepped a few times when you don't want it to.
Also, what's with the attitude, why bother asking for help of your not going to take it positively
Guest
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
